Restricting bandwidth from a particular vlan
jomo frank
Hello Expert,
I have a 2900 router at branch office.
This router has a 4 port switch card and two gigabyte ports.
The gigabyte port is use for wan connection and the 4 port switch card is use for lan connection.
I have two separate networks on my lan side. (network 1 and network 2)
I have assigned port 0,1 of the switch card to vlan1 for network 1
Ports 2,3 of the switch card is assigned vlan 20 for network 2
My problem is I would like to applied a bandwidth restriction for all data coming out from vlan20
capping same to 384 kb.
Note I do not want use QOS because this will only kickin when saturation occurs, I would
like this to apply regards if there is saturation or not.
How can I achieve the above.
jomo
8 Replies 8
adamclarkuk_2
Level 4
Level 4
Hi Jomo
Not all QoS features operate when the link is saturated.  The enhanced etherswitch module for the 2900 does support policing, see below.  Without knowing the part number for the module you have installed, I cannot say if your module supports policing.
Policing
Note To use policy maps, the enhanced EtherSwitch service module must be running the LAN Base image
Traffic-policing  policies on the enhanced EtherSwitch service module port for managing  how much of the port bandwidth should be allocated to a specific traffic  flow
In  Cisco IOS Release 12.2(25)SED and later, iIf you configure multiple  class maps for a hierarchical policy map, each class map can be  associated with its own port-level (second-level) policy map. Each  second-level policy map can have a different policer.
Aggregate  policing for policing traffic flows in aggregate to restrict specific  applications or traffic flows to metered, predefined rates
This would allow you the limit traffic using an ACL then apply the policy-map the the SVI interface for VLAN 20.
Hello adam,
Below is the spec from the router:
Cisco CISCO2901/K9 (revision 1.0) with 483328K/40960K bytes of memory.
Processor board ID FTX143701HR
4 FastEthernet interfaces
2 Gigabit Ethernet interfaces
1 Virtual Private Network (VPN) Module
DRAM configuration is 64 bits wide with parity enabled.
255K bytes of non-volatile configuration memory.
254464K bytes of ATA System CompactFlash 0 (Read/Write)
License Info:
License UDI:
Device#   PID                   SN
*0        CISCO2901/K9          FTX143701HR
Technology Package License Information for Module:'c2900'
Technology    Technology-package          Technology-package
              Current       Type          Next reboot
ipbase        ipbasek9      Permanent     ipbasek9
security      securityk9    Permanent     securityk9
uc            None          None          None
data          None          None          None
Hi I'm not 100% sure but from what I can tell, you might be in luck.
Create an ACL but with the details you need, ( ie standard or extended, my example uses standard )
access-list 1 permit any
Create your class and attach your ACL
class-map test
match access-group 1
Create your policy-map and attach your class
policy-map test
class test
police cir (value you want in bits)
apply the policy map to your SVI
interface vlan 20
service-policy input test
You can monitor that the policer is doing as expected using the command
show policy-map interface vlan20
Job done, good luck
When applying the service policy on the interface, be sure to apply for input and output.
service-policy output test
Rizwan Rafeek
jomo frank
Thanks for the policy map instructions I adjust my configuration to include as per post.
Nobody is current using that vlan, hence when i did show policy-map interface vlan20
no info returned
Will generate some traffic on the vlan to test the restriction.
A quick question if i use traffic shape will how this affect the restriction.
hello Adamclarke,
I notice when i applied the service policy input to the vlan interface i am able to save, but for some strange
reason when i recheck the config next day the policy is not there.
I should be mention i am using Cisco Sdm software to applied the policy to the interface.
Can you shed an light on this issuse.
Jomo
hello Adamclarke,
When i use 'putty' to connect to the router and applied the service-policy to the interface the following error was return
Diamond(config-if)#service-policy input  Vlan_limiting
Configuration failed!
I tring to recheck my access list, class-mappings and service policy to find the error.
Jomo
hello AdamClarke,
Below is copy of my config for the service-policy
sh object-group
Network object group InternalService
Description Internal Service Security Group
170.1.0.0 255.255.0.0
sh   access-list
Extended IP access list 102
10 permit ip object-group InternalService any (259783 matches)
#sh class-map
Class Map match-all Internal_Sec_out (id 6)
   Match access-group 102
Policy Map Vlan_limiting
   Class Internal_Sec_out
     police cir 384000 bc 12000
       conform-action transmit
       exceed-action drop
Jomo
