Restricting devices able to be connected to 800 series router's switch
darren.g
Level 5
Level 5
Folks.
I have a Cisco 887M router which I wish to restrict the devices allowed to be connected/allocated an IP address to two, and *only* two.
I can't, for the life of me, find out how to allow these two devices to connect to ANY port - I can configure a MAC restriction on a single port, but I don't know how to make it so that I can allow JUST these two devices to connect to any port in the 4 port switch/VLAN (VLAN 1 is used because the mongrel who set this up was lazy). I know the MAC addresses I want to allow
Anyone got any pointers on how I can do this? I *can* restrict any given port to the two MAC addresses - but if I try to add the MAC addresses to another port, they get removed from the initial one. I need to be able to have them connect to ANY port and work, but allow NOTHING else to work.
For those wondering, this is to counter a user who is utilising company resources for purposes not approved - and costing us quite a bit of money in the process.
10 Replies 10
acampbell
Darren,
Ithink this link will help you
http://www.cisco.com/en/US/docs/routers/access/800/860-880-890/software/configuration/guide/vlanconf.html#wp1055744
Alex.
Please rate useful posts.
Regards, Alex. Please rate useful posts.
Alex.
Already found that one, and I've gone through it half a dozen times.
I can set the ports to "dynamic" mode, assign a maximum number of allowed MAC addresses to 2, and (apparently) set the allowed MAC addresses - but when I check the config, I can't see if this definition of allowed MAC addresses is saved.
From the config, I get the following
mac-address-table secure maximum 2 FastEthernet0
mac-address-table secure maximum 2 FastEthernet1
mac-address-table secure maximum 2 FastEthernet2
mac-address-table secure maximum 2 FastEthernet3
Which is what I'd expect - but even though I entered the command in the format
mac-address-table dynamic xxxx.xxxx.xxxx fe 0 vlan 1
mac-address-table dynamic xxxx.xxxx.xxxx fe 1 vlan 1
mac-address-table dynamic xxxx.xxxx.xxxx fe 2 vlan 1
mac-address-table dynamic xxxx.xxxx.xxxx fe 3 vlan 1
I can't find anywhere in the config where this appears to be set or saved.
Is this normal? I can't afford to actually lock this guy out of his *legitimate* machines. Or does this only show up when the machines are connected/powered on (he turns them off when he's not officially "working" to avoid being monitored, so I can't see them in the mac table at the moment).
Thanks.
so you know the MAC addresses you want to block or the ones you want to permit ?
you could simply do a MQC policy applied to vlan 1 that is dropping packets with forbidden MAC source address.
Alain
Alain.
I know the ones I want to permit - I want to drop everything *except* the two permitted devices.
I don't even want non-approved devices to be allocated an IP address from the DHCP pool (on the router). Just a big, fat "No, you aren't going to work" when an unapproved device is connected.
Cheers
Would a VACL work?
You can use a MAC-ACL and match those MAC-addresses you want to permit and then block the rest.
It would look something like this:
mac access-list extended HOSTS-MAC-ADDRESSES
permit host HHHH:HHHH:HHHH any
vlan access-map RESTRICT-HOSTS
match mac address HOSTS-MAC-ADDRESSES
action forward
vlan filter RESTRICT-HOSTS vlan-list 1
Thanks for the suggestion
The command "mac access-list" doesn't appear to be an option on this device. otherwise, I think it'd work quite nicely.
Cheers.
Ok, but what about using the numbered MAC-ACL then?
Like this:
access-list 700 permit
Yeah, I can create the list, but I can't apply it to either the VLAN interface or the individual fast ethernet interfaces.
Thanks for the suggestion, though
darren.g
Level 5
Level 5
So I gave up and logged this with the TAC.
Apparently, this is an unsupported condition on the 800 series router, and can't be done.
The best I can do is to exempt every IP address in the local DHCP schemea and assign an address manually to the allowed MAC addresses.
Which won't help me if the guy is smart enough to assign himself an IP address on unapproved devices, but it's all I can do.
Thanks for everyone who had input.
preventing users from assigning a static IP can be done with a local or AD GPO for windows.
Regards.
Alain
