Revealing denied packets in Class-map ACLs
fsebera
Level 4
Level 4
In configuring Control Plane Policing (CPP),  I use ACLs to filter packets, not all packets pass the permit statements and thus are denied. How do I see which OTHER packets are being denied. I tried to add the “LOG” keyword to the end of the deny statement but IOS provided an error message stating the LOG is not an option in class-maps.
ERROR MESSAGE: R(config-ext-nacl)#110 deny tcp any any log class-map COPP_3 : access-list with 'log' not supported, pls remove 'log' from access-list otherwise class-map COPP_3 will not work properly
Anyone know a way to show which packets are being denied?
SAMPLE:
class-map match-any COPP_3
match access-group name MVID
class COPP_3
   police 768000 192000 conform-action transmit  exceed-action drop
ip access-list extended MVID
remark _____________________________VER.2
permit udp any host 224.0.1.1 eq ntp
permit udp 172.16.1.0 0.0.0.255 host 239.255.0.1 eq 5004
permit udp 172.16.1.0 0.0.0.255 any eq 5004
permit udp 172.0.0.0 0.255.255.255 any eq 5004
remark ------ PIM L3 Neighbor (PE3)
permit pim host 172.17.30.2 host 224.0.0.13
remark ------ Anycast RP (HUB1 or HUB2)
permit udp 172.31.255.0 0.0.0.255 eq pim-auto-rp host 224.0.1.39 eq pim-auto-rp
permit udp 172.16.0.0 0.0.0.255 eq pim-auto-rp host 224.0.1.39 eq pim-auto-rp
remark ------ Phantom-RP HUB1 F0/0.100
permit udp host 172.16.10.254 eq pim-auto-rp host 224.0.1.40 eq pim-auto-rp
remark ------ Phantom-RP HUB2 F0/0.200
permit udp host 172.16.20.254 eq pim-auto-rp host 224.0.1.40 eq pim-auto-rp
remark ------ LLMNR
deny  ip any host 224.0.0.252
deny  tcp any any
deny  udp any any
deny  ip any any
R#sh ip access-list MVID
       Extended IP access list MVID
     10 permit udp any host 224.0.1.1 eq ntp
     20 permit udp 172.16.1.0 0.0.0.255 host 239.255.0.1 eq 5004
     30 permit udp 172.16.1.0 0.0.0.255 any eq 5004
     40 permit udp 172.0.0.0 0.255.255.255 any eq 5004
     50 permit pim host 172.17.30.2 host 224.0.0.13 (20 matches)
     60 permit udp 172.31.255.0 0.0.0.255 eq pim-auto-rp host 224.0.1.39 eq pim-auto-rp (2 matches)
     70 permit udp 172.16.0.0 0.0.0.255 eq pim-auto-rp host 224.0.1.39 eq pim-auto-rp (2 matches)
     80 permit udp host 172.16.10.254 eq pim-auto-rp host 224.0.1.40 eq pim-auto-rp (8 matches)
     90 permit udp host 172.16.20.254 eq pim-auto-rp host 224.0.1.40 eq pim-auto-rp (9 matches)
     100 deny ip any host 224.0.0.252
     110 deny tcp any any (15 matches)
     120 deny udp any any (12 matches)
     130 deny ip any any (66 matches)
Frank
8 Replies 8
Collin Clark
I don't think you need the class-map keyword. Just 'log' should log the traffic to buffer/syslog.
SO, how do you configure Control Plane Policing without class-maps?
Please provide a sample configuration.
Tks
Frank
Sorry for not being clear. I meant just remove the class-map from the ACE
to
You do realize this is the ERROR MESSAGE produced by IOS and not a CLI entry -Right?
I didn't, I thought it was a CLI error. Let me dig in my stuff and see what else I can find.
Anyone else have any thoughts on how to troubleshoot Control Plane Policing ACLs¿¿¿
Frank
Got it figured out, no additional help needed - yet!!
Best
Frank
Any chance you can tell me what you did to resolve this? I've run into the exact same issue and there seems to be very little supporting information around...
Thanks!
