RING Topology at Distribution Level
nabeelcse07
I am working on a scenario. where requirement is to have a RING Topology between the distribution Switches. we have total 3 pairs of Distribution Switches and they will be configured as VSS.
In this Scenario is it possible to have a RING topology? if Yes! then how the Loop can be avoided in the network? How the RING will block the looping path? Assuming STP is not an option.
NA
mlund
Level 7
Level 7
If routed links is not an option, maybe "rep" can be.
See this explanation how it works.
https://www.cisco.com/c/en/us/td/docs/ios-xml/ios/lanswitch/configuration/xe-3s/lanswitch-xe-3s-book/lsw-cfg-rep.html
/Mikael
