rip 224.0.0.9 suppression not working
B@B@r
hi all i am working on rip
i want to break rip updates by denying 224.0.0.9
which is not working
my configurion
access-list 1 deny 224.0.0.9 0.0.0.0a
access-list 1 permit any
int fa0/0
ip access-group 1 in
ip access-group 1 out
but still, have rip route and ip debug rip is showing packet send with multicast address.
why shouldn't it blocked?
thanks
regard
babar
10 Replies 10
you need to use an extended IP access list:
access-list 101 deny ip any host 224.0.0.9
access-list 101 permit ip any any
Thankyou for your reply,
i tried it but still it is not working .
rip is still learning route from neighbor
i also did clear ip route *
show access-list 101
10 deny ip any host 224.0.0.9 (312 matches)
20 permit ip any any ( 12 matches)
inter fa0/0
ip access-group 101 in
Yogi-Bear
That multicast is a destination address and you are using standard access-list which only targrt source IP.
If you're interested there a functionality that achieve your purpose and it's used with the command passive-interface.
Dear bobby,
yeah i used standard access-list, but after guidance of first reply i tried for extended access list still it is not working.
i know about passive interface ,it stop sending routing updates i tried it is working perfactly...
But i want to block its multi-cast address using extended control list ...
it is not working
Alrigth can you please share the access-list, the port and RIP config ?
Did you apply the access list outbound as well ?
inter fa0/0
ip access-group 101 out
That should be it. Well done Georg!
Rip routes are still there
if it is not working could i block at udp layer 520....
what does your topology look like ? Do you have back to back routers with only one connection ?
You can't use an ACL to block outgoing RIP messages originated locally. ACL simply doesn't filter locally originated traffic. Thats why there's a "passive-interface" command.
You can however block inbound traffic. Make sure you create the ACL before trying to apply it to the interface otherwise it won't work. So give it a try agagain and recreate it.
