rip problem
jencomartin
Visitor
Hi.
I'm trying to solve one lab and i have problem with rip.
there are 2 routers (let's call them R1 and R2).
R1 have learned routes to networks 10.1.1.0/24, 10.1.2.0/24 etc.
R1 does not propagate this routes to R2.
There is rip v1 between the routers,
there is network 10.1.128.0/23 between the routers.
what can i do to get this routes from R1 to R2?
I must use rip version 1, i can't change addresses, subnet masks, I can't use any sumarization technique.
any ideas?
thanx
Route_reflector
Community Member
Sine you are using classless networks, there is no other way than configuring this as RIPV2.
Try RIPV2 if you can..
Rgds
