RIP
jonk34567
Level 4
Level 4
RIPv2 is a classless routing protocol.but when i  configuring Rip subnet mask information is not given. so how it can be considered as classless routing protocol ?
R2-TUT(config)#router rip
R2-TUT(config-router)#version 2
R2-TUT(config-router)#network 213.123.20.0
R2-TUT(config-router)#end
2 Accepted Solutions
Predrag Jovic
Level 3
Level 3
When - network 213.123.20.0 - command is present RIPv2 will check are any of interfaces belong to that specific network range. On all interfaces belong to networks that are considered subnets will:
- send out routing updates
- listen for incoming routing updates
- include network and subnet into all advertisement
 RIPv2 will include subnet mask along with network address that is configured under interface into RIP messages.
Deepak Kumar
Hi, It is right that RIP2 is classless routing protocol but it needs one more command as "No auto-Summery". The configuration of which interfaces are attached to the RIP process will check the subnet and the same subnet will attach to routing update. Regards, Deepak Kumar
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
5 Replies 5
Predrag Jovic
Level 3
Level 3
so what you are telling is that RipV2  will get the subnet mask information from interface ip configurations
Deepak Kumar
Deepak Kumar,
so what you are telling is that RipV2 will get the subnet mask information from interface ip/subnet mask configurations
Yes.
Deepak Kumar,
