RIPv2 authentication data calculation
rudolf.grezo
Community Member
i have a question about computing MD5 hash in RIPv2 authenticated packet. I am implementing RIPv2 software router and I need to find combination of input data to compute MD5 hash wich has to be checked when packet is recieved or appended when packet is send as update to another Cisco router.
I know that hash is computed minimum from key ID, sequence number, password and some things that I am looking for. Any advices greatly appreciated.
Best regards
RG
5 Replies 5
InayathUlla Sharieff
Hi Rudolf,
Note 1: When using plain text authentication mode, make sure that the following parameters are matching on neighboring routers for successful authentication.
  • Key-string
  • Authentication mode
Note 2: When using MD5 authentication mode, for successful authentication make sure that the following parameters are matching on neighboring routers.
  • Key-string
  • Key number
Some good ref on this:
http://evilrouters.net/2009/07/04/rip-authentication/
Inayath
*Plz rate all usefull posts.
Thank you, but question is not about configuration. Configuration is clear and easy to me.
cadet alain
Maybe you could take a look  here and  find some more info:http://tools.ietf.org/html/draft-ietf-ripv2-md5-03
Alain
Thank you, I have read this but still can't figure out the solution.
rudolf.grezo
Community Member
Hi all,
I found the solution. It was my mistake that I deleted the FFFF0001 and authentication data and replaced with password padded to 16 bytes. The FFFF0001 have to stay, only authentication data have to be replaced by padded password.
Thanks all for help.
