ME3600 does not support rstp!!!
Heiko.Bialozyt
       i have some ME-3600x. some of version 12.2 and one of version 15.5. te last one hast same config as all other. but if i check for rstp it sends
#sh spanning-tree
No spanning tree instance exists.
i know abount global config commands:
spanning-tree mode rapid-pvst
but there is no spanning-tree support. this causes many more problems. so it is important to solve spanning tee at first.
is it possible without downgrading this device?
thanks for help
Heiko
antonio.guirado
Level 3
Level 3
RSTP is the default spanning-tree mode for the Cisco ME. Could you send us your configuration?.
InayathUlla Sharieff
Hi Heiko,
Yes you are true
ME3600 doesn't support "true" RSTP
You get only this options:
3600X-A(config)#spanning-tree mode ?
 mst         Multiple spanning tree mode
 pvst        Per-Vlan spanning tree mode
 rapid-pvst  Per-Vlan rapid spanning tree mode
Inayath
*Plz rate all usefull posts.
what is "true" RSTP. Please read this:
http://www.cisco.com/en/US/docs/switches/metro/me3600x_3800x/software/release/12.2_52_ey/configuration/guide/swstp.html#wp1022949
I think that threre are not active port in the VLANs. So spanning-tree process is not active. Please try active a port and then see the
show spanning-tree command".
