06-17-2009 08:42 AM - edited 03-06-2019 06:19 AM
All,
When should you upgrade rommon? I've never done an upgrade, and I've only upgraded the IOS.
John
Solved! Go to Solution.
06-17-2009 08:47 AM
John
Put simply, when you need to. If you don't need to upgrade the ROMMON to run the software you want to run then leave well alone 🙂
Jon
06-17-2009 08:47 AM
John
Jon
06-17-2009 08:48 AM
That's what I figured 🙂
Thanks!
John
06-17-2009 02:46 PM
The new IOS, 12.4(50)SE series and later, will upgrade the switch's ROMmon to 12.2(44)SE5 (so you don't have a choice whether you want to upgrade the ROMmon or not).
Depending on the routers, I would take advantage of upgrading 1800, 2800, 3800 because there is one major feature I want: USB Boot
Otherwise, I'd follow the old adage: If it ain't broke, doooooooooooooooooooon't fix it.
Hope this helps.
