Rookie Question
Tom Simanovich
Hi, I haven't done anything Cisco since school about 8 years ago.  I have 5 Catalyst 2960-S Switches that I am setting up.
Basically I am just wanting to assign a Static IP address to each switch, using 192.168.11.30-192.168.11.34.  I will be setting up a VLAN for our wireless router, but plan to use the Cisco Network Assistant and not the CLI.
So basically I hooked up a console cable and connected and went through the basic setup.
I then went and assigned an ip address to VLAN1.  So my switch config looks like:
hostname Switch
boot-start-marker
boot-end-marker
no aaa new-model
spanning-tree mode pvst
vlan internal allocation policy ascending
interface FastEthernet0
  no ip address
  shutdown
interface GigabitEthernet0/1
interface GigabitEthernet0/2
interface GigabitEthernet0/3
interface GigabitEthernet0/4
interface GigabitEthernet0/5
interface GigabitEthernet0/6
interface GigabitEthernet0/7
interface GigabitEthernet0/8
interface GigabitEthernet0/9
interface GigabitEthernet0/10
interface GigabitEthernet0/11
interface GigabitEthernet0/12
interface GigabitEthernet0/13
interface GigabitEthernet0/14
interface GigabitEthernet0/15
interface GigabitEthernet0/16
interface GigabitEthernet0/17
interface GigabitEthernet0/18
interface GigabitEthernet0/19
interface GigabitEthernet0/20
interface GigabitEthernet0/21
interface GigabitEthernet0/22
interface GigabitEthernet0/23
interface GigabitEthernet0/24
interface GigabitEthernet0/25
interface GigabitEthernet0/26
interface Vlan1
  ip address 192.168.11.30 255.255.255.0
ip default-gateway 192.168.11.254
ip http server
ip http secure-server
line con 0
line vty 5 15
end
I then went and tried to discover the switch by going to the ip address in a web browser on the same subnet, and also using the Cisco Network assistant.  I can't get to it through either.  I also can't ping the IP address either.
Am I missing something completely obvious here?  Do I need to have done the copy startup-config running-config command after assigning the IP address for the switch?
Or was I supposed to not assign the IP to VLAN1 and assign it to something else.  I also wasn't sure what to answer to the question about Enter interface name used to connect to the management network from the above interface summary:  I answered VLAN1 to the question, was that wrong?
John Blakley
I see that fa0/0 is shutdown. Which port were you connected to? Are you in the same subnet as the switch, and if not, do you have the correct gateway configured in the switch?
HTH, John *** Please rate all useful posts ***
John Blakley
You're right, I didn't have the port set that I was using to connect to the switch.  I was just connecting through a normal port, but did not have the switchport mode and access mode set for that particular port.
Thanks for the quick response.
