I have a server with several (6-8) clients. Each has two 10-gig NICs and will be running Red Hat Enterprise 6.6. I want to use round robin load balancing to effectively double my throughput to 20-gig. The network is isolated and won't be reaching out to the internet, which should greatly reduce out-of-order packets. Each of the systems will be running channel bonding, mode 0. As a small added complication, the client systems will be PXE booted from the server.
How do I set up the switch to allow this? The switch is a Nexus 3064.
Thank you,
Chuck Martin
