Route leaking issues?
Shawnw4401
I am quite puzzled with the issue I am having. In my test, I had route-leaking setup. Saved the configurations and turned off the router. Next time I boot up the routers, my route-leaking isn't working.
Problem:
1) Computer VRF cannot ping any 10.1.0.0/30 or 10.1.0.4/30 IP address.
2) Servers VRF cannot ping any 10.1.0.0/30, 10.1.0.4/30, 10.2.0.0/30 or 10.2.0.4/30 IP address.
3) Wi-Fi VRF cannot ping any 10.2.0.0/30 or 10.2.0.4/30 IP address.
Router A)
version 15.1
hostname External_Router
boot-start-marker
boot-end-marker
no aaa new-model
dot11 syslog
ip source-route
ip cef
no ipv6 cef
voice-card 0
license udi pid CISCO3845-MB sn FOC105013BA
vtp domain MyTestLab.com
vtp mode transparent
vtp version 2
redundancy
interface Loopback1100
ip address 10.255.254.254 255.255.255.255
interface Loopback1200
ip address 10.255.255.254 255.255.255.255
interface GigabitEthernet0/0
no ip address
duplex auto
speed auto
media-type rj45
interface GigabitEthernet0/0.1100
description LAN Network
encapsulation dot1Q 1100
ip address 10.1.0.5 255.255.255.252
interface GigabitEthernet0/0.1200
description Wi-Fi Network
encapsulation dot1Q 1200
ip address 10.2.0.5 255.255.255.252
interface GigabitEthernet0/1
no ip address
duplex auto
speed auto
media-type rj45
interface GigabitEthernet0/1.1100
ip address 10.1.0.2 255.255.255.252
interface GigabitEthernet0/1.1200
ip address 10.2.0.2 255.255.255.252
interface FastEthernet0/0/0
no ip address
interface FastEthernet0/0/1
no ip address
interface FastEthernet0/0/2
no ip address
interface FastEthernet0/0/3
no ip address
interface Vlan1
no ip address
router ospf 1100
router-id 10.255.254.254
network 10.1.0.0 0.0.0.3 area 0
network 10.1.0.4 0.0.0.3 area 0
network 10.255.254.254 0.0.0.0 area 0
router ospf 1200
router-id 10.255.255.254
network 10.2.0.0 0.0.0.3 area 0
network 10.2.0.4 0.0.0.3 area 0
network 10.255.255.254 0.0.0.0 area 0
ip forward-protocol nd
no ip http server
no ip http secure-server
ip route 0.0.0.0 0.0.0.0 10.1.0.1
ip route 0.0.0.0 0.0.0.0 10.2.0.1
ip route 10.25.0.0 255.255.255.240 GigabitEthernet0/0.1100 10.1.0.6
ip route 10.49.0.32 255.255.255.240 GigabitEthernet0/0.1200 10.2.0.6
ip route 10.71.0.16 255.255.255.240 GigabitEthernet0/0.1100 10.1.0.6
ip route 10.71.0.16 255.255.255.240 GigabitEthernet0/0.1200 10.2.0.6
control-plane
mgcp profile default
line con 0
exec-timeout 0 0
login local
line aux 0
line vty 0 4
login
transport input all
scheduler allocate 20000 1000
Router B)
version 15.1
service password-encryption
hostname Internal_Router
boot-start-marker
boot-end-marker
!card type command needed for slot 1
no aaa new-model
dot11 syslog
ip source-route
ip vrf Computers
rd 1025:1
route-target export 1025:1
route-target import 1071:1
ip vrf MGMT
rd 1300:1
ip vrf Servers
rd 1071:1
route-target export 1071:1
route-target import 1049:1
route-target import 1025:1
ip vrf Wi-Fi
rd 1049:1
route-target export 1049:1
ip cef
no ipv6 cef
voice-card 0
license udi pid CISCO3845-MB sn FOC1411592J
redundancy
interface Loopback1025
ip vrf forwarding Computers
ip address 10.10.25.255 255.255.255.255
interface Loopback1049
ip vrf forwarding Wi-Fi
ip address 10.10.49.255 255.255.255.255
interface Loopback1071
ip vrf forwarding Servers
ip address 10.10.71.255 255.255.255.255
ip address 10.255.254.253 255.255.255.255
ip address 10.255.255.253 255.255.255.255
interface Loopback1300
ip vrf forwarding MGMT
ip address 10.10.130.255 255.255.255.255
no ip address
duplex auto
speed auto
media-type rj45
interface GigabitEthernet0/0.1025
encapsulation dot1Q 1025
ip address 10.25.0.1 255.255.255.240
interface GigabitEthernet0/0.1049
encapsulation dot1Q 1049
ip address 10.49.0.33 255.255.255.240
interface GigabitEthernet0/0.1071
encapsulation dot1Q 1071
ip address 10.71.0.17 255.255.255.240
interface GigabitEthernet0/0.1300
encapsulation dot1Q 1300
ip address 10.3.0.1 255.255.255.240
no ip address
duplex auto
speed auto
media-type rj45
ip address 10.1.0.6 255.255.255.252
ip address 10.2.0.6 255.255.255.252
router ospf 1100
router-id 10.255.254.253
network 10.255.254.253 0.0.0.0 area 0
router ospf 1200
router-id 10.255.255.253
network 10.255.255.253 0.0.0.0 area 0
router bgp 1300
bgp router-id 10.10.130.255
bgp log-neighbor-changes
address-family ipv4
redistribute connected
exit-address-family
address-family ipv4 vrf Computers
bgp router-id 10.10.25.255
exit-address-family
address-family ipv4 vrf Servers
bgp router-id 10.10.71.255
exit-address-family
address-family ipv4 vrf Wi-Fi
bgp router-id 10.10.49.255
exit-address-family
no ip http server
ip route 0.0.0.0 0.0.0.0 10.1.0.5
ip route 0.0.0.0 0.0.0.0 10.2.0.5
ip route 10.25.0.0 255.255.255.240 GigabitEthernet0/0.1025
ip route 10.49.0.32 255.255.255.240 GigabitEthernet0/0.1049
ip route 10.71.0.16 255.255.255.240 GigabitEthernet0/0.1071
ip route vrf Computers 0.0.0.0 0.0.0.0 GigabitEthernet0/1.1100 10.1.0.5 global
ip route vrf Servers 0.0.0.0 0.0.0.0 GigabitEthernet0/1.1100 10.1.0.5 global
ip route vrf Servers 0.0.0.0 0.0.0.0 GigabitEthernet0/1.1200 10.2.0.5 global
ip route vrf Wi-Fi 0.0.0.0 0.0.0.0 GigabitEthernet0/1.1200 10.2.0.5 global
control-plane
line con 0
exec-timeout 0 0
logging synchronous
login local
line aux 0
line vty 0 4
login
transport input all
I am pretty sure I am not messing anything. Also, I tried re-doing BGP, but once I deleted the BGP and re-add the same commands, BGP wouldn't work anymore. I had to reload the router to fix that issue. Any help would be greatly appreciated. Thank you!
23 Replies 23
Ok i can help you on Wireshark.
Do you mind sending me the full config (password removed) of your 2 routers?
Also give me more info about equipments you're using (model and version)
Francesco
PS: Please don't forget to rate and select as validated answer if this answered your question
Francesco,
Here are those documents (sorry it took so long too).
Both routers are a 3845 version 15.1(4)M9.
I'm sorry for my late answer í was out for couple of days.
I'll review your files.
In which timezone are you?
We can eventually do a quick WebEx to review it.
Before doing that, on your router, in the enable mode, can you validate you have the command monitor capture point and buffer?
Francesco
Francesco,
I am in central timezone. I can do a WebEx anytime between 5 PM to 10 PM (1700-2200) CST.
If you would like to do it over a weekend, I am available at any time though.
Hi.
Your internal router text file isn't the right one. On this file, there is still the external router config.
Are you available now to do a troubleshooting session?
Francesco
Francesco,
Sorry, I wasn't able to do anything today. I will get you the configs. Let me know what time works best for you with the timezone. I'll make sure I set the time aside to be able to troubleshoot.
Hey,
Based on your latest config and debug messages on external routers, everything seems to be fine.
I'm in EST timezone and I'm available today if you can. Let me by pinging me through private chat.
Francesco
Francesco,
I am available today as well. Now if you'd like.
Hey,
We've done a private troubleshooting session.
We've issue the command ip routing protocol purge interface to force a purge of the RIB for interface going down. We've shutted down ospf neighbor with ASA firewall to be sure that there wasn't any issue related with ASA.
Everything works perfectly. Bring back ASA, add route-map to redistribute specific subnets on different ospf process with ASA.
PS: Please mark as correct answer if this answered your question
Francesco
