route-map and CPU
csco11579831
Hi all,
Could you plz tel me why the route-map overlopping the CPU ?
i have a 3570G with ios 15.X
Best regard,
Bilal Nawaz
Hello, please could you kindly show us the output of 'show proc cpu sorted' it might be a bug, so also please show us an output of 'show ver'
What are you using your route-map for? Please show us the configuration of the route-map too.
I would strongly advise you to downgrade to IOS version 12.2(55)SE7 which is probably the most stable version of IOS for this platform. Unless there are certain features in IOS 15 that you need.
It's unanimously agreed on the forum that 12.2(55)SE7 is the best code to be on - so we have this as a backup plan if we cannot help solve your problem, please see what difference it made for me here: https://supportforums.cisco.com/thread/2222308
Hope this helps.
Please rate useful posts & remember to mark any solved questions as answered. Thank you.
Hi M.Nawaz,
here is sh version together with sh ...sorted:
######################################sh version#########################
Cisco IOS Software, Catalyst 4000 L3 Switch Software (cat4000-I5K91S-M), Version 12.2(25)EWA11, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2007 by Cisco Systems, Inc.
Compiled Thu 25-Oct-07 16:37 by kellythw
Image text-base: 0x10000000, data-base: 0x115CBF68
ROM: 12.2(20r)EW1
Dagobah Revision 226, Swamp Revision 5
COREWMRBT101 uptime is 12 weeks, 3 days, 4 hours, 47 minutes
System restarted at 04:29:35 UTC Thu Mar 28 2013
System image file is "bootflash:"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco WS-C4948 (MPC8245) processor (revision 0) with 262144K bytes of memory.
Processor board ID FOX11300297
MPC8245 CPU at 266Mhz, Fixed Module
Last reset from PowerUp
4 Virtual Ethernet interfaces
48 Gigabit Ethernet interfaces
511K bytes of non-volatile configuration memory.
Configuration register is 0x2101
######################################sh proc cpu sorted#########################
CPU utilization for five seconds: 34%/8%; one minute: 33%; five minutes: 33%
PID Runtime(ms)   Invoked      uSecs   5Sec   1Min   5Min TTY Process
  30  32232139881941437191       1660 17.67% 16.46% 14.88%   0 Cat4k Mgmt LoPri
  29   2466929121421464047        173  6.07%  8.19%  9.53%   0 Cat4k Mgmt HiPri
   5     9940576   1150847       8637  1.43%  0.19%  0.13%   0 Check heaps
  58         356        59       6033  0.31%  0.02%  0.01%   1 SSH Process
  55    11947136  49960257        239  0.15%  0.11%  0.10%   0 IP Input
122     1311904  40823727         32  0.07%  0.05%  0.07%   0 IP-EIGRP(0): HEL
  36       76152   1853298         41  0.07%  0.01%  0.00%   0 Compute load avg
  26        5872   7532267          0  0.07%  0.00%  0.00%   0 TTY Background
  24       17220   3269274          5  0.07%  0.00%  0.00%   0 Net Background
  10           0         2          0  0.00%  0.00%  0.00%   0 AAA high-capacit
   9           0         1          0  0.00%  0.00%  0.00%   0 AAA_SERVER_DEADT
  12         128    125572          1  0.00%  0.00%  0.00%   0 IPC Dynamic Cach
   8           0         2          0  0.00%  0.00%  0.00%   0 Serial Backgroun
   7           0         2          0  0.00%  0.00%  0.00%   0 Timers
  11           0         1          0  0.00%  0.00%  0.00%   0 Policy Manager
SWBBXXX#sh bootflash:
-#- ED ----type---- --crc--- -seek-- nlen -length- ---------date/time--------- name
1   .. image        C036258C  C96D18   34 12938392 Nov 2 2007 13:37:14 +00:00 cat4000-i5k91s-mz.122-25.EWA11.bin
Hello, first in your original post you stated you had a problem with a 3750X, but your subsequent posts suggest you have a problem with a C4948 ?
If this is the case please use this document to help troubleshoot the problem.
http://www.cisco.com/en/US/products/hw/switches/ps663/products_tech_note09186a00804cef15.shtml
If you searched the forum before posting, you could have found that many people have similar problems with the above and the processes although your CPU is below 35% at the time you posted.
There are various bugs related to the processes using the most CPU resources. I would advise you to contact TAC for assistance.
This kind of problem is known to happen when MAC addresses expire and are being learnt again. There are two bugs stated in the document that start with "CSC" so just do a search for them, although there is a possibility that you may be hitting another bug too stated in other posts on the forum.
