Route Map Issue
NES IT
Hi All,
I have a Cisco3560G switch that has a route map places on one of the SVI interfaces. I am trying to tftp from the switch to the NMS (which is on the same VLAN) yet when the route map is in place, it fails (although the NMS see's the traffic, it times out). Can anyone explain why this would happen?
Extended IP access list Management-Route-Map-ACL
    10 deny icmp any host 10.11.130.162 (10 matches)
    20 deny ip any host 10.11.130.163
    30 deny ip any host 10.11.130.164
    40 permit ip 10.11.130.160 0.0.0.15 any (89 matches)
interface Vlan160
description Management Network - L3 Interface
ip address 10.11.130.162 255.255.255.240
ip access-group Management-Zone-ACL-In in
ip policy route-map Management-Route-Map-ACL
Switch address 10.11.130.162
NMS Address 10.11.130.163
With route map applied...
SEP-CSW-01#copy run tftp
Address or name of remote host []? 10.11.130.163
Destination filename [sep-csw-01-confg]?
%Error opening tftp://10.11.130.163/sep-csw-01-confg (Timed out)
With route map removed...
41053 bytes copied in 2.693 secs (15244 bytes/sec)
Im stumped!
Giuseppe Larosa
Hello Daniel,
may you post the route-map configuration ?
because you have defined an IP extended ACL and then you try to call a route-map with the same name.
if the route-map does not exist IOS does not warn you.
Hope to help
Giuseppe
Hey Giuseppe,
Route map and ACL can have the same name, but mine are slightly different. Here is the route map config.
SEP-CSW-01#sh route-map Management-Route-Map
route-map Management-Route-Map, permit, sequence 10
  Match clauses:
    ip address (access-lists): Management-Route-Map-ACL
  Set clauses:
    ip next-hop 10.11.130.161
  Policy routing matches: 9 packets, 1281 bytes
Dan
its ok, resolved it.
I needed a deny statement in the route map for the traffic from NMS to switch. As below:
SEP-CSW-01#sh ip access-list Management-Route-Map-ACL
    10 deny icmp any host 10.11.130.162 (1 match)
    20 deny ip host 10.11.130.162 host 10.11.130.163
    30 deny ip host 10.11.130.163 host 10.11.130.162 (98 matches)
    40 permit ip 10.11.130.160 0.0.0.15 any (2 matches)
