Route-map problem with VSS
Dear Friends, I am facing a problem with 6509 VSS. I want to divert few traffic from one of the SVI to the Sonicwall Firewall which is directly connected to my VSS. I have created a PBR on he VSS and applied it on the SVI. But packet are not coming to the Sonicwall. The VSS is having normal routing table from OSPF.
Anybody has faced problem with the route map in VSS or any sugestions???
Reza Sharifi
Can you post your config and the version of IOS you are using?
