Route map question
tedauction
Level 5
Level 5
Hello, can someone please confirm if this will work as expected ?
I have a host 10.23.150.15. I want to modify the next hop for traffic ONLY from this host to ONLY 192.168.8.0, 192.168.9.0, 192.168.10.0 and 192.168.13.0.
All other traffic from this host will follow the normal default gateway configured on their NIC.
Thank you kindly.
Extended IP access list codec
10 permit ip host 10.23.150.15 192.168.8.0 0.0.0.255
20 permit ip host 10.23.150.15 192.168.9.0 0.0.0.255
30 permit ip host 10.23.150.15 192.168.10.0 0.0.0.255
40 permit ip host 10.23.150.15 192.168.11.0 0.0.0.255
50 permit ip host 10.23.150.15 192.168.13.0 0.0.0.255
route-map codec
match ip address codec
set default next-hop 10.21.250.45
Then on the router:
int gi0/0.30
ip policy route-map codec
2 Accepted Solutions
filip00011
Level 3
Level 3
Yes this will work
Richard Burts
There are a couple of things about your environment that we do not know and which could change our answer. We do not know what platform and version of code this is, and so can not be sure that Policy Based Routing is supported. We do not know whether interface g0/0.30 is the interface where the host is connected.
Other than that your suggested config looks correct, except that your ACL includes network 192.168.11.0 and that network was not mentioned in your verbal description of the requirements. Other than that you seem to be correct for PBR.
Rick
Rick
filip00011
Level 3
Level 3
Yes this will work
Richard Burts
Rick
Rick
Larry Sullivan
Level 7
Level 7
I would also consider if asymmetric routing is an issue if destination network has multiple ingress/egress points with dynamic routing.
