Route Map - Sequence Numbers
Andy.S
Community Member
Hi All,
Hi All,
Taking the cisco example below, which demos how to PBR.
access-list 1 permit 209.165.200.225
access-list 2 permit 209.165.200.226
interface ethernet 1
 ip policy route-map Texas
route-map Texas permit 10
 match ip address 1
 set ip precedence priority
 set ip next-hop 209.165.200.227
route-map Texas permit 20
 match ip address 2
 set ip precedence critical
 set ip next-hop 209.165.200.228
Examples I've seen generally start sequence numbers from '10'.  Any reason why I couldnt use 1-9 to insert a new condition before route-map Texas permit 10   e.g route-map Texas permit 5 ?
Andy
Rajeev Sharma
Hey Andy,
Its just easy to interpret, you may use any any number:
R1(config)#route-map test ?
  <0-65535>  Sequence to insert to/delete from existing route-map entry
  deny       Route map denies set operations
  permit     Route map permits set operations
  <cr>
HTH.
RS.
Jon Marshall
Andy
No reason at all. In fact that is usually why you see this numbering ie. it allows you to modify your route map without having to delete and recreate it.
Jon
