Route-Reflector
alsayed
HI
how i can do verification if The Route-Reflector-Client Work properly>
10xs
Danilo Dy
Hi Ali,
Typical setup is that route-reflector is connected to external domain while route-reflector-client is in the same domain with route-reflector but not connected to any external domain (no way of learning external routes by itself).
In the route-reflector router where you configured "neighbor route-reflector-client", execute "show ip bgp neighbor " and from the output you should see "route ref client: True".
The external route that route-reflector received should reflect to the route-reflector-client (no change on the next hop). So "show ip bgp" output from the route-reflector should be the same if not similar to the "show ip bgp" output from route-reflector-client for external learned routes of route-reflector.
The objective of route-reflector is to "reflect" the external learned routes to route-reflector-client
Dandy
Hi medan!
sh ip bgp neigh y.y.y.y(there r no mention for route Reflector info:
Network Next Hop Metric LocPrf Weight Path
2)why we need BGP Cluster?
10xs
