Route VLAN internet traffic through a specific WAN Interface
Cameron McKay
I have a 2851 router acting as our Vlan router. There is a default route pointing to Gi0/0 which is our primary internet gateway. We recently installed a second satellite based internet link and I need to route internet traffic from a specific VLAN out this interface and to the internet instead of the default route.
Can anyone point me in the right direction in terms of a simple config. I've tried simply adding an IP route with the next hop being the satellite modem gateway, but it's not working.
The 2851 is the default router for the Vlan in question, and has an interface of Gi0/1.32
Thanks.
11 Replies 11
jonathanaxford
Level 3
Level 3
Hi Cameron,
It sounds like Policy Routing may help you here - I don't have a huge amount of experience with it myself but the following doco may help:
http://www.cisco.com/en/US/tech/tk365/technologies_tech_note09186a008009481d.shtml
Many thanks
Jonathan
Hi Cameron,
Lets assume that your vlan  has the following ip range 203.12.70.0/24.
So, the config would be as follows on your 2851 router.
access-list 110 permit ip 203.12.70.0 0.0.0.255 any log
route-map SELECT-203 permit 10
match ip address 110
set next-hop
route-map SELECT-203 permit 20
int gi0/1
ip policy route-map SELECT-203
HTH,
Please rate if helpful
Thanks Kishore,
I entered the commands as described and still cannot route traffic from my two VLAN's. attached is the config (external IP's / PW's removed).. is there anything that you (or anyone) can see that would prevent routing traffic from 10.17.1.0 and 10.16.1.0 out to 80.92.49.162 ?
Hi Cameron,
Your attachment still isn't available (queued) so I can't see the config. Did you apply the policy to the g0/1 interface or the g0/1.32 subinterface? It should go on the subinterface.
Ian
Hi Cameron,
My bad..typo. It should go on the respective subinterface. Also, your attachment is queued. Cant see it.
Please rate if helpful.
Hmm.. even applied to the sub interface it's not routing...
Any ideas based on the attached config ? (fixed)
In the route map instead of ip next-hop, try the set interface f0/0/0 command instead, and let me know what happens.
Otherwise it might be an idea to do a debug ip packet and term mon to capture some debug data. The access-list should be one to limit traffic you want to see and to avoid putting the CPU at 100%
Ian
The router won't accept the command. I'm receiving a : Warning: Use P2P interface for routemap setinterface clause error ?
It's because it's an ethernet link...otherwise it should accept it.
Can you do a #sh ip route
and post the results here. 'Cos it should work with the setup you got. Can you even ping the next hop address that you are trying to reach?
Also, you are natting on these interfaces. Does the traffic know the route back from the other side? Maybe you are sending data but it down't know how to come back to natted address?
Sorry talking rubbish here.
Let me think....
Do you see the translations when you do a #sh ip nat trans ?
Can you successfully ping the next hop?
In your config you have this:
ip nat inside source route-map nonat interface GigabitEthernet0/0 overload
but you a re missing a statement for the outside nat on the f0/0/0 interface.
So it looks like a NAT problem.
access-list 110 permit ip 10.16.1.0 255.255.255.0 any
ip nat inside source list 110 interface fastethernet0/0/0 overload
That should do the trick.
Ian
