routed port and ACLs
anitachoi3
Hi Expert,
Below is the configuration of the catalyst 4506 core switch. The mail server is connected to GE port directly with IP address, the server farm is other zone for the web servers. Two ACL will be deployed to protect the critical server. Is it the correctly to config the direction of ACL to be "in"?
! 4506
hostname hkcoresw01
interface GigabitEthernet3/1
description connected to Primary Exchange Mail Server, 192.168.200.8/27
no switchport access
ip address 192.168.200.1 255.255.255.224
ip access-group MailIn in
load-interval 30
no cdp enable
no ip redirects
no ip proxy-arp
interface GigabitEthernet2/2
description connected to server farm
switchport access vlan 50
switchport mode access
interface Vlan50
description server farm on 8/F
ip address 192.168.50.1 255.255.255.0
ip access-group ServerFarmIn in
no ip redirects
no ip proxy-arp
standby 50 ip 192.168.50.10
standby 50 priority 150
standby 50 preempt delay reload 60
ip access-list extended ServerFarmIn
permit tcp 192.168.50.64 0.0.0.3 any eq 80
permit tcp 192.168.50.64 0.0.0.3 eq 80 any
permit tcp 192.168.50.64 0.0.0.3 any eq 443
permit tcp 192.168.50.64 0.0.0.3eq 443 any
permit tcp host 192.168.50.30 eq ssh host 192.168.1.66
permit tcp host 192.168.50.30 eq rdp host 192.168.1.66
ip access-list extended MailIn
permit tcp 192.168.0.0 0.0.255.255 192.168.200.8 0.0.0.7 eq pop3
permit tcp host 172.16.1.1 192.168.200.8 0.0.0.7 eq smtp
permit tcp host any eq smtp 192.168.200.8 0.0.0.7 established
rdgs
Anita
Anita
It's the same principle for a L3 routed port as for a L3 SVI  ie. from your config -
L3 vlan 50 interface - subnet 192.168.50.0/24
L3 routed interface - subnet  192.168.200.0/27
an acl applied inbound will filter traffic coming from clients in that subnet so -
vlan 50 acl applied inbound will filter traffic from 192.168.50.x clients.
vlan 50 acl applied outbound will filter traffic going to 192.168.50.x clients
L3 routed interface acl applied inbound will filter traffic from 192.168.200.x clients
L3 routed interface acl applied outbound will filter traffic to 192.168.200.x clients
So looking at one line from your Mailin acl -
you can see from the descriptions above that this line wil never be used. An acl applied inbound expects to see the source IPs from the subnet it is applied to but the source IP in that acl line is 172.16.1.1. So that suggests it should be applied outbound not inbound.
Also the destination makes no sense either. If the only device on the link is the mailserver then simply use it's host adddress which i'm guessing is 192.168.200.8.
The whole config is very confused. Why are you using a ./27 for the mailsevrer subnet ie.
192.168.200.0 255.255.255.224 = 192.168.200.1 -> 30 (broadcast 31). So you have 30 useable IPs but you only 2 devices on that subnet if the mailserver is directly connected to the gig port on the switch.
So it's difficult to give any advice without knowing exactly what you are trying to do.
Jon
Jon Marshall
Anita
The ServerFarmin acl doesn't even mention the Mail server so how is related to the 192.168.200.1 server ?
The Mailin acl looks to be applied incorrectly. Not sure again it is that you are trying to achieve.
Can you explain exactly what you want to do and then we can go from there.
For your info -
an acl applied inbound means traffic coming from that vlan. So with your Mailin acl the acl is applied to traffic received FROM the mailserver so you can see that your acl probably isn't correct.
Jon
Dear Jon,
GE 3/1 is configured to be routed port (not SVI setting) for the mail server (Exchange server). Do I treat it the same as router's interface? if so, I apply the ACL to the routed port of 4506 to be the same manner with router. Please correct me if I wrong.
rdgs
Anita
Anita
Jon
Hi Jon,
There are some information to be masked and amended, so the configuration may not be certain or clear. Thank you for the elaboration and convey the main idea and concept of L3 routed interface for ACL depolyment.
rdgs
Anita
