Routed ports on catalyst 4k6 please help
andreagentile71
hi,
i know how to configure a routed port on a 3560/3750
interface gigabit x/x/x
no switchport
ip x.x.x.x x.x.x.x
no shut
but which command i need, to configure a routed port on a catalyst 4006?
it is equipped with supervisor I and 2 modules, 34 and 48 ports.
modules use cat os, supervisor use ios.
(please note, i wish to have a routed port, not a port in a vlan with an ip address)
thanks in advance for help
In this way , basically your module in slot 3 WS-X4232-L3 is a router and if you want to do intervlan routing , that is the card you will need to configure.On the supervisor itself , you can neither create an SVI or a routed port.
Here is a sample config for doing routing via WS-X4232-L3 module.
http://www.cisco.com/warp/customer/473/28.html
szahid
Level 3
Level 3
CatOS based supervisor ( ws-x4013 ) on a 4006 switch is a L2 supervisor which means it does not support routed ports.
You need sup2+ ( ws-x4013+ ) at the minimum to enable routing on a 4006 switch.
Salman
it is equipped this way:
Mod Port Model Serial # Versions
1 2 WS-X4013 XXXXXXXXXXX Hw : 3.2
Gsp: 7.6(4.0)
Nmp: 7.6(4)
2 6 WS-X4306 XXXXXXXXXXX Hw : 2.0
3 34 WS-X4232-L3 XXXXXXXXXXX Hw : 1.7
4 48 WS-X4148-RJ XXXXXXXXXXX Hw : 3.0
so, i think i'll need to create a vlan and give an ip to it, right?
thanks a lot, really
