router 7604 is not accepting some of class-map commands!!!!
Dr.X
Level 2
Level 2
hi ,
my router is 7604 , with ios
bootdisk:c7600s3223-adventerprisek9-mz.152-1.S.bin
i have some commands in class maps is not being accepted from router , i mean i cant type
these config was workign ok on 7200
with ios  advance ip service and every thing was ok ,
my question is  do i need to upgarde my current ios on 7600 to access these QOS commands ??
is there any solutions ??
the followign commadns is not being accepted by the router
class-map match-any WEB_SENSTIVE
match protocol http mime "text*"
match protocol http mime "image*"
match protocol http mime "application/x-javascript"
match protocol http mime "application/javascript"
match protocol http mime "application/xml"
class-map match-all ICMP
match protocol icmp
class-map match-all P2P
match protocol bittorrent
match protocol kazaa2
match protocol fasttrack
match protocol gnutella
match protocol edonkey
class-map match-all rrr
match access-group name rrr
class-map match-all BUS
match access-group name BUS
class-map match-all VIP
match access-group name VIP
class-map match-any VIDEO
match protocol http mime "video*"
class-map match-any MANAGMENT
match protocol snmp
match protocol telnet
match protocol ssh
match protocol ospf
match protocol bgp
match protocol dns
Hello Ahmed,
sup32 PISA is not listed among possible supervisors in C7604 chassis datasheet
http://www.cisco.com/en/US/prod/collateral/routers/ps368/ps6316/product_data_sheet0900aecd8027cc3e.html
>> Supervisor support: Cisco Catalyst 6500 Supervisor  Engine 32 (WS-SUP32-GE-3B and WS-SUP32-10GE-3B), Cisco Catalyst 6500  Supervisor Engine 720 (WS-SUP720-3B and WS-SUP720-3BXL), and the new  Cisco Route Switch Processor 720 (RSP720-3C and RSP720-3CXL)
I'm sorry this may be bad news for you
Hope to help
Giuseppe
Giuseppe Larosa
Hello Ahmed,
the problem is likely caused by the match protocol statements, because they require support for NBAR and NBAR is not supported on all C7600-C6500 supervisors.
It is not a question of IOS image, but rather of different features supported at platform level and it is determined by supervisor type.
only sup32 PISA version supports NBAR
see
http://www.cisco.com/en/US/prod/collateral/modules/ps2797/ps7209/product_data_sheet0900aecd805a6b87_ps708_Products_Data_Sheet.html
compare with sup32 datasheet
http://www.cisco.com/en/US/prod/collateral/modules/ps2797/ps5972/product_data_sheet0900aecd801c5cab_ps708_Products_Data_Sheet.html
check the supervisor type with show module
Hope to help
Giuseppe
hi ,
thanks soo much for ur reply
i read the tables and seems that my module which is    cant handle these   QOS commands ,
but i think that if i bought the module pisa  32 , it will sove my problem .
i read from table that pisa 32 chasis requirement:
All Cisco Catalyst 6500 Series chassis with fan tray 2 or E-Series fan tray and 2500W power supplies or above
does that speech mean that it is supprted to 7604 ??? does this module
Supervisor Engine 32 PISA
being   supported by 7604 ???
regards
Hello Ahmed,
Hope to help
Giuseppe
