ROUTER 887VA NOT CONNECTING TO SKY ADSL PPPOA - PLEASE HELP!!!
deskguest
I am new to Cisco and am trying to configure my router 887VA to use my sky adsl.  I have configured as below and need some help and it is not connecting to the internet.  I get a solid LED on the CD indicator of the router.  Any help will be much appreciated.
DHCP appear to be working as the PC has an DHCP address.
I have replaced the Sky username and password with XXXXX but the real ones are present withe current config.
Building configuration...
Current configuration : 2238 bytes
! No configuration change since last restart
version 15.1
no service pad
service password-encryption
hostname ROUTER
boot-start-marker
boot-end-marker
enable secret 5 $1$p7FT$P8Nx4Ah3WeWeJ48v5C1ca/
no aaa new-model
memory-size iomem 10
ip source-route
ip dhcp excluded-address 192.168.3.1 192.168.3.99
ip dhcp pool DHCP-POOL
import all
network 192.168.3.0 255.255.255.0
default-router 192.168.3.1
dns-server 8.8.8.8
domain-name HOME.LOCAL
ip cef
no ip domain lookup
no ipv6 cef
license udi pid CISCO887VA-K9 sn XXXXXXX
controller VDSL 0
interface Ethernet0
no ip address
shutdown
interface ATM0
no ip address
no atm ilmi-keepalive
pvc 8/35
encapsulation aal5mux ppp dialer
dialer pool-member 1
interface FastEthernet0
no ip address
interface FastEthernet1
no ip address
interface FastEthernet2
no ip address
interface FastEthernet3
no ip address
interface Vlan1
ip address 192.168.3.1 255.255.255.0
ip nat inside
ip virtual-reassembly in
interface Dialer0
description WAN interface
ip address negotiated
ip mtu 1492
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
ppp authentication chap callin
ppp chap hostname XXXXXXXXXXXXX
ppp chap password 7 XXXXXXXXXXXXXXXXX
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat inside source list ACL-LAN-TO-WAN interface Dialer0 overload
ip route 0.0.0.0 0.0.0.0 Dialer0
ip access-list extended ACL-LAN-TO-WAN
deny ip any 10.0.0.0 0.255.255.255
deny ip any 172.16.0.0 0.15.255.255
deny ip any 192.168.0.0 0.0.255.255
dialer-list 1 protocol ip permit
banner motd ^C
Unauthorized access is prohibited to this router.
***********************************************************************^C
line con 0
exec-timeout 0 0
password 7 14141B180F0B
logging synchronous
login
line aux 0
line vty 0 4
password 7 00071A150754
login
transport input all
end
The debug is clearly showing that your router is trying to negotiate with the
far end
LCP: O CONFREQ
These are OUTBOUND (O) messages from your router but you never see any INBOUND (I) messages from
the other end
You will need to check with the ISP that you have the correct broadband set up like PPPOA or
should you be using PPPOE , is you line good etc etc
Alex
Regards, Alex. Please rate useful posts.
7 Replies 7
acampbell
Your NAT list access list is basically denying everything
Remember access lists have an implicit deny all at the end which you dont see
re-write your access list to only allow traffic from your lan
no ip access-list extended ACL-LAN-TO-WAN
 premit ip 192.168.3.0 0.0.0.255 any
Alex
Than you Alex for your response.  I have followed your instruction and have removed and added the above lines as per instruction but unfortunately I am still receiving no internet and a solid cd LED on the router.  I receive a 192.168.3.100 ip from my host and can ping the router 192.168.3.1 successfully.  Any other ideas please?  Updated show run is as follows:
show run
Current configuration : 2159 bytes
version 15.1
no service pad
hostname ROUTER
boot-start-marker
boot-end-marker
no aaa new-model
ip source-route
--More-- !
import all
dns-server 8.8.8.8
ip cef
no ip domain lookup
no ipv6 cef
license udi pid CISCO887VA-K9 sn FCZ1606C0RG
--More-- !
controller VDSL 0
interface Ethernet0
no ip address
shutdown
interface ATM0
no ip address
pvc 8/35
no ip address
--More-- !
no ip address
no ip address
no ip address
interface Vlan1
ip nat inside
interface Dialer0
ip mtu 1492
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
--More-- ppp authentication chap callin
no ip http server
permit ip 192.168.3.0 0.0.0.255 any
banner motd ^C
--More-- Unauthorized access is prohibited to this router.
line con 0
exec-timeout 0 0
logging synchronous
login
line aux 0
line vty 0 4
login
transport input all
end
ROUTER#
Your config looks ok to me now.
Can you confirm that you are successfully authenticating chap and receiving ip address from the ISP.
show ip int brief
If no address is being received for int dialer 0 then you may need to
run "debug ppp negotiation & debug ppp authentication"
Please also check you have the correct username & password from the ISP
Alex
Still not conencting.  I am not receiving an IP address from the ISP and have copied the debug info from the debug ppp negotiaition and debug ppp authentication as below.  A lot of it was repeated so I deleted some out out but essentially it repeats as below.  Any other ideas will be welcome.  I cannot confirm the user details - Sky refuses to confirm them!! But believe these to be correct as I took these from my current working router config. Thanks again.
ROUTER#show ip int brief
Interface                  IP-Address      OK? Method Status                Protocol
ATM0                       unassigned      YES NVRAM  up                    up
Dialer0                    unassigned      YES NVRAM  up                    up
Ethernet0                  unassigned      YES NVRAM  administratively down down
FastEthernet0              unassigned      YES unset  down                  down
FastEthernet1              unassigned      YES unset  down                  down
FastEthernet2              unassigned      YES unset  down                  down
FastEthernet3              unassigned      YES unset  down                  down
NVI0                       unassigned      YES unset  administratively down down
Virtual-Access1            unassigned      YES unset  up                    up
Virtual-Access2            unassigned      YES unset  up                    down
Vlan1                      192.168.3.1     YES NVRAM
Nov 11 19:00:22.043: Vi2 PPP DISC: LCP failed to negotiate
Nov 11 19:00:22.043: PPP: NET STOP send to AAA.
Nov 11 19:00:22.043: Vi2 PPP: No remote authentication for call-out
Nov 11 19:00:22.043: Vi2 LCP: Event[Timeout-] State[REQsent to Stopped]
Nov 11 19:00:22.043: Vi2 LCP: Event[DOWN] State[Stopped to Starting]
Nov 11 19:00:22.043: Vi2 PPP: Phase is DOWN
Nov 11 19:00:23.043: PPP: Alloc Context [85DB83DC]
Nov 11 19:00:23.043: ppp40 PPP: Phase is ESTABLISHING
Nov 11 19:00:23.043: Vi2 PPP: Using dialer call direction
Nov 11 19:00:23.043: Vi2 PPP: Treating connection as a callout
Nov 11 19:00:23.043: Vi2 PPP: Session handle[A5000028] Session id[40]
Nov 11 19:00:23.043: Vi2 LCP: Event[OPEN] State[Initial to Starting]
Nov 11 19:00:23.043: Vi2 PPP: No remote authentication for call-out
Nov 11 19:00:23.043: Vi2 LCP: O CONFREQ [Starting] id 1 len 10
Nov 11 19:00:23.043: Vi2 LCP:    MagicNumber 0x2B1578E3 (0x05062B1578E3)
Nov 11 19:00:23.043: Vi2 LCP: Event[UP] State[Startin
ROUTER#g to REQsent]
ROUTER#
Nov 11 19:00:25.051: Vi2 LCP: O CONFREQ [REQsent] id 2 len 10
Nov 11 19:00:25.051: Vi2 LCP:    MagicNumber 0x2B1578E3 (0x05062B1578E3)
Nov 11 19:00:25.051: Vi2 LCP: Event[Timeout+] State[REQsent to REQsent]
ROUTER#
Nov 11 19:00:27.067: Vi2 LCP: O CONFREQ [REQsent] id 3 len 10
Nov 11 19:00:27.067: Vi2 LCP:    MagicNumber 0x2B1578E3 (0x05062B1578E3)
Nov 11 19:00:27.067: Vi2 LCP: Event[Timeout+] State[REQsent to REQsent]
ROUTER#
Nov 11 19:00:29.083: Vi2 LCP: O CONFREQ [REQsent] id 4 len 10
Nov 11 19:00:29.083: Vi2 LCP:    MagicNumber 0x2B1578E3 (0x05062B1578E3)
Nov 11 19:00:29.083: Vi2 LCP: Event[Timeout+] State[REQsent to REQsent]
ROUTER#
Nov 11 19:00:31.099: Vi2 LCP: O CONFREQ [REQsent] id 5 len 10
Nov 11 19:00:31.099: Vi2 LCP:    MagicNumber 0x2B1578E3 (0x05062B1578E3)
Nov 11 19:00:31.099: Vi2 LCP: Event[Timeout+] State[REQsent to REQsent]
ROUTER#
Nov 11 19:00:33.115: Vi2 LCP: O CONFREQ [REQsent] id 6 len 10
Nov 11 19:00:33.115: Vi2 LCP:    MagicNumber 0x2B1578E3 (0x05062B1578E3)
Nov 11 19:00:33.115: Vi2 LCP: Event[Timeout+] State[REQsent to REQsent]
ROUTER#
Nov 11 19:00:35.131: Vi2 LCP: O CONFREQ [REQsent] id 7 len 10
Nov 11 19:00:35.131: Vi2 LCP:    MagicNumber 0x2B1578E3 (0x05062B1578E3)
Nov 11 19:00:35.131: Vi2 LCP: Event[Timeout+] State[REQsent to REQsent]
ROUTER#
Nov 11 19:00:37.147: Vi2 LCP: O CONFREQ [REQsent] id 8 len 10
Nov 11 19:00:37.147: Vi2 LCP:    MagicNumber 0x2B1578E3 (0x05062B1578E3)
Nov 11 19:00:37.147: Vi2 LCP: Event[Timeout+] State[REQsent to REQsent]
ROUTER#
Nov 11 19:00:39.163: Vi2 LCP: O CONFREQ [REQsent] id 9 len 10
Nov 11 19:00:39.163: Vi2 LCP:    MagicNumber 0x2B1578E3 (0x05062B1578E3)
Nov 11 19:00:39.163: Vi2 LCP: Event[Timeout+] State[REQsent to REQsent]
ROUTER#
Nov 11 19:00:41.179: Vi2 LCP: O CONFREQ [REQsent] id 10 len 10
Nov 11 19:00:41.179: Vi2 LCP:    MagicNumber 0x2B1578E3 (0x05062B1578E3)
Nov 11 19:00:41.179: Vi2 LCP: Event[Timeout+] State[REQsent to REQsent]
ROUTER#
Nov 11 19:00:43.195: Vi2 PPP DISC: LCP failed to negotiate
Nov 11 19:00:43.195: PPP: NET STOP send to AAA.
Nov 11 19:00:43.195: Vi2 PPP: No remote authentication for call-out
Nov 11 19:00:43.195: Vi2 LCP: Event[Timeout-] State[REQsent to Stopped]
Nov 11 19:00:43.195: Vi2 LCP: Event[DOWN] State[Stopped to Starting]
Nov 11 19:00:43.195: Vi2 PPP: Phase is DOWN
Nov 11 19:00:44.195: PPP: Alloc Context [85DB83DC]
Nov 11 19:00:44.195: ppp41 PPP: Phase is ESTABLISHING
Nov 11 19:00:44.195: Vi2 PPP: Using dialer call direction
Nov 11 19:00:44.195: Vi2 PPP: Treating connection as a callout
Nov 11 19:00:44.195: Vi2 PPP: Session handle[76000029] Session id[41]
Nov 11 19:00:44.195: Vi2 LCP: Event[OPEN] State[Initial to Starting]
Nov 11 19:00:44.195: Vi2 PPP: No remote authentication for call-out
Nov 11 19:00:44.195: Vi2 LCP: O CONFREQ [Starting] id 1 len 10
Nov 11 19:00:44.195: Vi2 LCP:    MagicNumber 0x2B15CB93 (0x05062B15CB93)
Nov 11 19:00:44.195: Vi2 LCP: Event[UP] State[Startin
Nov 11 19:00:46.203: Vi2 LCP: O CONFREQ [REQsent] id 2 len 10
Nov 11 19:00:46.203: Vi2 LCP:    MagicNumber 0x2B15CB93 (0x05062B15CB93)
Nov 11 19:00:46.203: Vi2 LCP: Event[Timeout+] State[REQsent to REQsent]
Nov 11 19:00:48.219: Vi2 LCP: O CONFREQ [REQsent] id 3 len 10
Nov 11 19:00:48.219: Vi2 LCP:    MagicNumber 0x2B15CB93 (0x05062B15CB93)
Nov 11 19:00:48.219: Vi2 LCP: Event[Timeout+] State[REQsent to REQsent]
Nov 11 19:00:50.235: Vi2 LCP: O CONFREQ [REQsent] id 4 len 10
Nov 11 19:00:50.235: Vi2 LCP:    MagicNumber 0x2B15CB93 (0x05062B15CB93)
Nov 11 19:00:50.235: Vi2 LCP: Event[Timeout+] State[REQsent to REQsent]
Nov 11 19:00:52.251: Vi2 LCP: O CONFREQ [REQsent] id 5 len 10
Nov 11 19:00:52.251: Vi2 LCP:    MagicNumber 0x2B15CB93 (0x05062B15CB93)
Nov 11 19:00:52.251: Vi2 LCP: Event[Timeout+] State[REQsent to REQsent]
Nov 11 19:00:54.267: Vi2 LCP: O CONFREQ [REQsent] id 6 len 10
Nov 11 19:00:54.267: Vi2 LCP:    MagicNumber 0x2B15CB93 (0x05062B15CB93)
Nov 11 19:00:54.267: Vi2 LCP: Event[Timeout+] State[REQsent to REQsent]
Nov 11 19:00:56.283: Vi2 LCP: O CONFREQ [REQsent] id 7 len 10
Nov 11 19:00:56.283: Vi2 LCP:    MagicNumber 0x2B15CB93 (0x05062B15CB93)
Nov 11 19:00:56.283: Vi2 LCP: Event[Timeout+] State[REQsent to REQsent]
Nov 11 19:00:58.299: Vi2 LCP: O CONFREQ [REQsent] id 8 len 10
Nov 11 19:00:58.299: Vi2 LCP:    MagicNumber 0x2B15CB93 (0x05062B15CB93)
Nov 11 19:00:58.299: Vi2 LCP: Event[Timeout+] State[REQsent to REQsent]
Nov 11 19:01:00.315: Vi2 LCP: O CONFREQ [REQsent] id 9 len 10
Nov 11 19:01:00.315: Vi2 LCP:    MagicNumber 0x2B15CB93 (0x05062B15CB93)
Nov 11 19:01:00.315: Vi2 LCP: Event[Timeout+] State[REQsent to REQsent]
ROUTER#no debug ppp negotiation
Nov 11 19:01:02.331: Vi2 LCP: O CONFREQ [REQsent] id 10 len 10
Nov 11 19:01:02.331: Vi2 LCP:    MagicNumber 0x2B15CB93 (0x05062B15CB93)
Nov 11 19:01:02.331: Vi2 LCP: Event[Timeout+] State[REQsent to REQsent]
Nov 11 19:01:04.347: Vi2 PPP DISC: LCP failed to negotiate
Nov 11 19:01:04.347: PPP: NET STOP send to AAA.
Nov 11 19:01:04.347: Vi2 PPP: No remote authentication for call-out
Nov 11 19:01:04.347: Vi2 LCP: Event[Timeout-] State[REQsent to Stopped]
Nov 11 19:01:04.347: Vi2 LCP: Event[DOWN] State[Stopped to Starting]
Nov 11 19:01:04.347: Vi2 PPP: Phase is DOWN
Nov 11 19:01:05.347: PPP: Alloc Context [85DB83DC]
Nov 11 19:01:05.347: ppp42 PPP: Phase is ESTABLISHING
Nov 11 19:01:05.347: Vi2 PPP: Using dialer call direction
Nov 11 19:01:05.347: Vi2 PPP: Treating connection as a callout
Nov 11 19:01:05.347: Vi2 PPP: Session handle[7A00002A] Session id[42]
Nov 11 19:01:05.347: Vi2 LCP: Event[OPEN] State[Initial to Starting]
Nov 11 19:01:05.347: Vi2 PPP: No remote authentication for call-out
Nov 11 19:01:05.347: Vi2 LCP: O CONFREQ [Starting] id 1 len 10
Nov 11 19:01:05.347: Vi2 LCP:    MagicNumber 0x2B161E41 (0x05062B161E41)
Nov 11 19:01:05.347: Vi2 LCP: Event[UP] State[Startin
far end
LCP: O CONFREQ
the other end
Alex
As Sky do not want to disclose any info at all I've has to do some of my own research.  I have confirmed from the current router status the ADSL username and password.  The current router is using PPPoA.  The only difference that I did notice was that it uses vcmux but the router does only allows me to configure aal5mux and about 3 other options but not vcmux.  Could this be causing an issue?
After researching the vc-mux I realised I was using the correct network traffic control (aal5vdmux) so I decided to look at the config again.  I realised that Sky uses 0/38 as the VPI/VCI and I had 8/35 in the interface ATM0 settings.  After changing this the connection was made but I was receiving 'chap authentication failure' errors.  I checked all combinations of the username XXXX@skydsl and password that I could find but none of them connected.
What I found did connect was the following details:
username:install@o2broadband.co.uk
password:install
So to summarize, use the above credentials to config the non Sky router that you have and this should connect you.
The previous show run config was good (but use 0/38 as the VPI/VCI settings, vc-mux (aal5vcmux)) for the setup of the Cisco 887VA using PPPoA for Sky ADSL customers.
Will be leaving Sky soon as they did not disclose the username and password to me and for cost reasons!!!  There's alot of broadband and phone deals which are alot cheaper!!!
Thanks to Alex for all your help.  My first Cisco problem resolved!!!!
