Router boots with wrong IOS
I am having one 3825 Router for which I planned to change one of the faulty FAN. After replacing I powered on the Router and it booted with the wrong IOS "c3825-advipservicesk9-mz.124-9.T6.bin" instead "c3825-advipservicesk9-mz.124-24.T5.bin ".  I am using "boot system url-path" command instead "boot system flash url-path" command. Please confirm what can be the possible issue since I have already consulted so many documents but have not found any clue.
Config-Register:
show version
Partial Running-Config:
boot-start-marker
boot system flash:c3825-advipservicesk9-mz.124-24.T5.bin
boot-end-marker
Dir Flash Output:
Router#dir
Directory of flash:/
    1  -rw-    41080124  Jan 26 2008 01:17:16 +04:00  c3825-advipservicesk9-mz.124-9.T6.bin
   11  -rw-    60423188  Nov 24 2011 18:20:52 +04:00  c3825-advipservicesk9-mz.124-24.T5.bin
   12  -rw-         660  Feb 18 2015 15:16:00 +04:00  vlan.dat
http://www.lab.dit.upm.es/~labrst/config/ciscopedia/boot%20system.htm
https://www.safaribooksonline.com/library/view/cisco-ios-cookbook/0596527225/ch01s08.html
http://routing-bits.com/2009/10/11/bootsystem/
2 Accepted Solutions
I Tend to agree with Leo. :)
Try verifying you prefeerd IOs
verify /md5 flash:c3825-advipservicesk9-mz.124-24.T5.bin
According to CCO your MD5 result should be:-
22e20b3bad8d2771f068267046ecbbde
Alex
Regards, Alex. Please rate useful posts.
On a router, none.  Just "sh run" will give you the output.
On a switch, the command is "sh bootvar".
6 Replies 6
Leo Laohoo
Maybe the IOS is corrupt.
Alex
I verified the checksum it was OK.
Issue fixed once I removed the second IOS "c3825-advipservicesk9-mz.124-9.T6.bin" from Flash and it booted from my desired IOS "c3825-advipservicesk9-mz.124-24.T5.bin". Currently I only have one IOS in my flash.
I believe there is some problem with "boot system" command which I have entered. Can you explain what is the exact difference of using the "flash" keyward before "url-path"
Like what is the difference between below two commands ?
1- boot system flash:c3825-advipservicesk9-mz.124-24.T5.bin
1- boot system flash flash:c3825-advipservicesk9-mz.124-24.T5.bin
The second command is incorrect.  The correct syntax is "boot system flash:IOS.bin".  The second command is correct if you're dealing with 6000/6500 system.
Hi Leo,
Thanks for your response. Do we have any command which can show us current "boot loader register" value just like we have "show bootvar" since I cannot see this command in 3825.
Thanks/Regards
