Router Cisco 1941 Series/Switch Cisco Catalyst 2960-X SERIES config
dwtdlt3000
I need help with my switch, my router has internet. but i'm trying to get internet to my switch now.
if i drop my Show Running Config, Could somebody help me with my Issue Please?
10 Replies 10
dwtdlt3000
Router Cisco 1941 Series   Switch CISCO CATALYST 2960-X SERIES
Current configuration : 2427 bytes
! Last configuration change at 20:09:42 CST Wed Nov 8 2023
! NVRAM config last updated at 20:11:51 CST Wed Nov 8 2023
version 15.4
service password-encryption
hostname Panda-Bear
boot-start-marker
boot-end-marker
enable secret 5 XXXXXXXXXXXXXXXXXXUNeD.
no aaa new-model
clock timezone CST -5 0
clock summer-time CDT recurring
clock calendar-valid
ip dhcp excluded-address 192.168.0.1 192.168.0.20
ip dhcp excluded-address 192.168.100.1 192.168.100.12
ip dhcp pool Home_Test
network 192.168.100.0 255.255.255.0
dns-server 75.75.75.75
default-router 192.168.0.2
no ip domain lookup
ip cef
no ipv6 cef
cts logging verbose
license udi pid CISCO1941/K9 sn FTX175182WX
username Darrell privilege 15 secret 5 XXXXXXXXXXllp7y.
redundancy
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
ip address 192.168.0.2 255.255.255.0
ip nat outside
ip virtual-reassembly in
duplex auto
speed 1000
interface GigabitEthernet0/1
ip address 192.168.100.1 255.255.255.0
ip nat inside
duplex auto
speed auto
interface GigabitEthernet0/0/0
no ip address
shutdown
duplex auto
speed auto
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat inside source list 1 interface GigabitEthernet0/0 overload
ip route 0.0.0.0 0.0.0.0 192.168.0.1
ip route 10.0.10.0 255.255.255.0 192.168.100.2
ip route 10.0.20.0 255.255.255.0 192.168.100.2
ip route 10.0.30.0 255.255.255.0 192.168.100.2
ip route 10.0.40.0 255.255.255.0 192.168.100.2
access-list 1 permit 192.168.100.0 0.0.0.255
access-list 1 permit 10.0.10.0 0.0.0.255
access-list 1 permit 10.0.20.0 0.0.0.255
access-list 1 permit 10.0.30.0 0.0.0.255
access-list 1 permit 10.0.40.0 0.0.0.255
control-plane
line con 0
password 7 XXXXXXXXXXXXXXXXX5345
logging synchronous
login
line aux 0
logging synchronous
line 2
no activation-character
no exec
transport preferred none
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line vty 0 4
password 7 XXXXXXXXXXXXXXX766
no login
no exec
transport input ssh
scheduler allocate 20000 1000
pnp profile pnp_profile
transport http host devicehelper.cisco.com port 80
end
dwtdlt3000
Cisco Catalyst 2960 x
Current configuration : 4971 bytes
! Last configuration change at 19:17:35 UTC Tue Feb 22 2000
! NVRAM config last updated at 19:22:40 UTC Tue Feb 22 2000
version 15.2
no service pad
hostname Waynes-Word2.0
boot-start-marker
boot-end-marker
no aaa new-model
switch 1 provision ws-c2960x-48fps-l
ip routing
ip dhcp pool 10
network 10.0.10.0 255.255.255.0
default-router 10.0.10.1
ip dhcp pool 20
network 10.0.20.0 255.255.255.0
default-router 10.0.20.1
ip dhcp pool 30
network 10.0.30.0 255.255.255.0
default-router 10.0.30.1
ip dhcp pool 40
network 10.0.40.0 255.255.255.0
default-router 10.0.40.1
crypto pki trustpoint TP-self-signed-2336641152
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-2336641152
revocation-check none
rsakeypair TP-self-signed-2336641152
crypto pki certificate chain TP-self-signed-2336641152
certificate self-signed 01
spanning-tree mode rapid-pvst
vlan internal allocation policy ascending
interface FastEthernet0
no ip address
no ip route-cache
shutdown
interface GigabitEthernet1/0/1
switchport access vlan 10
switchport mode access
interface GigabitEthernet1/0/2
interface GigabitEthernet1/0/3
interface GigabitEthernet1/0/4
interface GigabitEthernet1/0/5
interface GigabitEthernet1/0/6
interface GigabitEthernet1/0/7
interface GigabitEthernet1/0/8
interface GigabitEthernet1/0/9
interface GigabitEthernet1/0/10
interface GigabitEthernet1/0/11
interface GigabitEthernet1/0/12
interface GigabitEthernet1/0/13
interface GigabitEthernet1/0/14
interface GigabitEthernet1/0/15
interface GigabitEthernet1/0/16
interface GigabitEthernet1/0/17
interface GigabitEthernet1/0/18
interface GigabitEthernet1/0/19
interface GigabitEthernet1/0/20
interface GigabitEthernet1/0/21
interface GigabitEthernet1/0/22
interface GigabitEthernet1/0/23
interface GigabitEthernet1/0/24
interface GigabitEthernet1/0/25
interface GigabitEthernet1/0/26
interface GigabitEthernet1/0/27
interface GigabitEthernet1/0/28
interface GigabitEthernet1/0/29
interface GigabitEthernet1/0/30
interface GigabitEthernet1/0/31
interface GigabitEthernet1/0/32
interface GigabitEthernet1/0/33
interface GigabitEthernet1/0/34
interface GigabitEthernet1/0/35
interface GigabitEthernet1/0/36
interface GigabitEthernet1/0/37
interface GigabitEthernet1/0/38
interface GigabitEthernet1/0/39
interface GigabitEthernet1/0/40
interface GigabitEthernet1/0/41
interface GigabitEthernet1/0/42
interface GigabitEthernet1/0/43
interface GigabitEthernet1/0/44
interface GigabitEthernet1/0/45
interface GigabitEthernet1/0/46
interface GigabitEthernet1/0/47
interface GigabitEthernet1/0/48
interface GigabitEthernet1/0/49
interface GigabitEthernet1/0/50
interface GigabitEthernet1/0/51
interface GigabitEthernet1/0/52
interface Vlan1
ip address 192.168.100.2 255.255.255.0
interface Vlan10
ip address 10.0.10.1 255.255.255.0
interface Vlan20
ip address 10.0.20.1 255.255.255.0
interface Vlan30
ip address 10.0.30.1 255.255.255.0
interface Vlan40
ip address 10.0.40.1 255.255.255.0
ip http server
line con 0
password 7 XXXXXXXXXXXXXXXXXXXX4754
logging synchronous
login
line vty 0 4
login
line vty 5 15
login
M02@rt37
Hello @dwtdlt3000,
You have activate "ip routing" on your Switch but ther's no ip route..... that's the problem.
But, I suggest you to reconsider and adapt the Switch and the Router's configuration:
Create a ROAS on Router side ; meaning a sub-interface for interface GigabitEthernet0/1:
description --ROAS-SWITCH
no shut
interface GigabitEthernet0/1.10
encaspulation dot1q 10
ip nat inside
interface GigabitEthernet0/1.20
encaspulation dot1q 20
ip nat inside
interface GigabitEthernet0/1.30
encaspulation dot1q 30
ip nat inside
interface GigabitEthernet0/1.40
encaspulation dot1q 40
ip nat inside
ROAS: https://study-ccna.com/configure-roas/
On switch side, the interface facing Router's Gi0/1 interface, configure a traditionnal TRUNK:
switchport mode trunk
switchport encapsulation dot1q
switchport trunk allowed vlan 10,20,30,40
If you want "access to Internet" from the switch create an interface vlan 10 as example and add IP address. Test a pinf towards 8.8.8.8 with source <IP-interface-vlan-10>
=> No more "routing" needed on your Switch, acting as a traditional "L2" Switch.
Delete the DHCP server on Switch and confgure it on the Router
ip dhcp pool 10
ip dhcp pool 20
ip dhcp pool 30
ip dhcp pool 40
=>Your LAN should be able to access to Internet after that.
Best regards
I will Reply when i get a chance to add your suggestion, been a BUSY Weekend.
Thank you for your help!
this helped out, i haven't messed with anything in a couple days but i did add the ip route to the switch.
the Vlans still didn't do what i needed, but i will reply back to this post when i actually start messing with the devices again.
got some vouchers expiring soon, so i'm gone see where my progress is.
dec 4 my vouchers expire.
Reza Sharifi
For VLANs 20, 30. 40. etc.. to have access to the Internet, the switch needs a default route pointing to the IP address of the router.
ip route 0.0.0.0 0.0.0.0 192.168.100.1
you need in SW
ip route 0.0.0.0 0.0.0.0 <link connect router to SW>
ip routing
you need in R
ip route VLAN's SVI <line connect router to SW>
that what you need
i added the IP Route to the switch.
when i get free time i'm gone work on the svi for the router, i'll let you know when i get a chance to work on it.
thank you for reaching back out to me when you got a free chance as well.
