02-01-2012 09:40 PM - edited 03-07-2019 04:41 AM
I am using Cat6509-V-E chassis with redundant SUP-2T with ACE module. I am running
IOS version: bootdisk:s2t54-advipservicesk9_npe-mz.SPA.150-1.SY.bin
ACE version: 4.1
I installed ACE on module 4 & 1. But in both the cases i am getting the velow error message:
Router# *Feb 1 10:53:25.459: %C6KPWR-4-DISABLED: power to module in slot 4 set off (New fabric sync sequence not supported)
Router# *Feb 1 11:51:25.459: %C6KPWR-4-DISABLED: power to module in slot 1 set off (New fabric sync sequence not supported)
If i console in ACE it gives me the below output while booting (attached)...
Did anyone of you faced such issue? Kindly sugegst
02-01-2012 09:49 PM
A4(1.0) code. This is not a supported version on SUP2T(chassis hardware
being used by you). Please refer the following release notes which say:
http://www.cisco.com/en/US/docs/interfaces_modules/services_modules/ace/vA4_2_x/release/note/ACE_mod_rn_A42x.html#wp546207
The minimum required ACE30 module software version for Supervisor Engine 2T
support is A4(2.1a) or later. This ACE software version supports both
supervisor engine models: VS-S2T-10G and VS-S2T-10G-XL.
This is the reason for getting "New fabric sync sequence not supported"
messages. Therefore please upgrade ACE module to A4(2.1) in order to run it
on SUP2T. I would request you to seat this module in a supported SUP
hardware like SUP720. Once loaded, please upgrade to A4(2.1). Then you can
plug it back to the current SUP.
Following was the enhancement filed for SUP2T support:
It was supported finally in A4(2.1) upwards.
Hope this helps,
Nik
02-08-2012 11:03 AM
Thanks for your reply. Your suggestion solved my issue..thanks a lot…
