router interface
austindaz
Level 2
Level 2
Hi There
Is it possible to ping a router interface that is correctly setup but does not have anything connected to it? For instance I can ping the router from my pc but am wondering if I can ping a secondary port on the router that is properly configured but is not patched.
thanks
5 Replies 5
Edison Ortiz
No, the interface must be up/up and the only way the interface is up/up is by connecting it to another device.
__
Edison.
Correct me if I am wrong, but I think you can ping an interface that is down on a router as long as proxy arp is enabled on the interface that receives the arp request.
Not that this is very likely to be the case, but still....
Leo
gauravshar
Level 5
Level 5
I just tried that, it is working.. getting RTO's.
--gaurav
I meant its not working, getting RTO's.. in above post.
thanks very much for your responses
