01-15-2007 08:54 PM - edited 03-05-2019 01:47 PM
Anybody know what the diff. is between "Network Modules" and "Port-Adapters", as in NM-4E and PA-4E. Only thing I could find is that on the 7200 then are reffered to as PA and on the branch routers it's NM.
Thanks!
Solved! Go to Solution.
01-15-2007 09:02 PM
Hi chris,
You are almost right.. on the 7200 & 7500 series routers, we have 2/4/6 slots for the WAN ports to terminate.. such modules are called as the port adaptors.. PA's are normally higher end adaptors used in such routers.. Network modules fit in to low end routers like 1800/2800/3800 etc... They also can accomodate WAN circuits like T1/E1/DS3/Ethernet etc... I guess it has to do more with the naming convention of Cisco...
Hope this helps.. all the best..
Raj
01-15-2007 09:02 PM
Hi chris,
Raj
01-15-2007 09:06 PM
Thanks for the reply!
