Router on a Stick Config connecting to another remote router
larryferrara
I have an issue where I have a router a stick config working just fine. However when I add another router that connects to the router on a stick I can not ping the remote subnet from the PC's using the router on the stick. The router servicing those PC's can ping the other router but the PC's using that router on a stick can not. Not sure what could be the issue. Oh yeah I am using Packet Tracer
Mark Malone
If you can post a screenshot of the topology the way it is now and the configs in text file we can take a look , if you upload it in PT I wont be able to see it though , it sounds as if some routes are missing since the new router was installed
I will post the configs and topology tonight. Thank You!
Julio E. Moisa
The reason can be because there is no a routing protocol like RIP, OSPF, EIGRP, etc to share network information between the routers, also you can use static routing, other reason could be a filtering method applied over the path to the remote computers.
If you have packet tracer you can zip it and upload the file or upload text files with the configs.
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
