Router on a stick not pinging from vtp client hosts ?
jordan-jj
Hello
I got below scenario but my host in vlan 200 not pinging to my default gateway
While I removed vtp transparent switch the host can ping the gateway
How to make vlan routing works in the above scenario ?
6 Replies 6
Jon Marshall
On the VTP transparent switch did you create the vlan in the vlan database ?
Jon
Yes...
manual Vlan 200
Yes...
manual Vlan 200
yes ..
vlan 200 manual entered
chrihussey
Just out of curiosity, if you change switch 1 from client to transparent (and create VLAN 200), can the host then ping the gateway?
so on the transparent switch you created the VLAN:
Switch1#conf t
Switch1(config)#vlan 200
Switch1(config)#end
And the trunk interfaces look like below:
Switch#sh interfaces trunk
Port Mode Encapsulation Status Native vlan
Gi0/0 on 802.1q trunking 1
Gi0/1 on 802.1q trunking 1
Port Vlans allowed on trunk
Gi0/0 1-4094
Gi0/1 1-4094
Port Vlans allowed and active in management domain
Gi0/0 1,200
Gi0/1 1,200
Port Vlans in spanning tree forwarding state and not pruned
Gi0/0 1,200
Gi0/1 1,200
