Router on a stick VS Layer 3 routing
Aloffawy
So i have been thinking, which is preferable supposing all required hardware are available for both. Configuring router on a stick or configuring inter vlan routing on a layer 3 switch.
Jon Marshall
L3 switch is generally a better approach for all but the smallest business.
The reason is with router on a stick all vlans share the bandwidth of the physical interface whereas with a L3 switch you get the full switching capacity.
Obviously L3 switches do not have the full feature support of routers.
Jon
Jon Marshall
Jon
Thanks for the quick reply Jon.
Just to add to what Jon has noted, there's often a huge performance difference between a L3 switch and a software based router, especially for the price. For example, a high-performance 4451 can router up to 2 Gbps, while multi gig port L3 switches can do wire speed for all their gig ports.
