Router RIP trouble shoot
tp067376
How do i trouble shoot my router rip network? i deleted and configure again but it doesn't work with the network i just assigned.
9 Replies 9
tp067376
I couldnt ping from lan to another lan
Reza Sharifi
i am still unable to solve the problem by use the config guide. Could you help me check? the password is cisco
I am not able to open your attachment. Can you change the format and report?
Also, is this from packet tracer ?
Could you try this file?
i am trying to fix with the debug ip rip command
Hi @tp067376
 I believe you misunderstood the concept of Passive interface
The definition would be:
"Sets the interface as passive, meaning that routing updates will not be sent out this interface. NOTE: For RIP, the passive-inter-face command will prevent the inter-face from sending out routing updates but will allow the interface to receive updates."
You need to remove passive interface command from all routers.
Take a look on the file I am attaching. All PCs can ping each other.
hi, remove passive interface from se0/0 in router KB and penang. then remove passive interface  @tp067376
Good luck
KB
Martin L
RIP should not be on any exam nowdays! not sure why you study it?  anyway, in case of RIP, make sure you run version 2 and no auto-summary command is present for all RIP routers.
Regards, ML
**Please Rate All Helpful Responses **
