Multicast between switches - Same VLAN
TimJenkins
Frequent Visitor
Frequent Visitor
I have a VoIP solution that resides in a single VLAN and which requires Multicast for PTP Time synchronisation.  The PTP Master/Slave election is based on Serial number of each device so the Source or Receiver could theoretically be on any one of a number Access Switches & Ports.  2 x VoIP units plugged into the same switch, PTP works.
PTP multicast traffic seems to fail when traversing switches.  I've been through this guide which I think is the problem,  (https://www.cisco.com/c/en/us/support/docs/switches/catalyst-6500-series-switches/68131-cat-multicast-prob.html#anc30) however, from the 5 solutions listed in it......
Solution 1 - "ip pim sparese-dense-mode" isn't a valid command on an N5K
Solution 2 - "ip igmp snooping querier" isn't a valid command on an N5K
Solution 3 - "ip igmp snooping vlan......" command not available on N9K
Solution 4 - Doesn't look scalable
Solution 5 - Cisco recommendation on N9K is to not disable IGMP snooping.
Network Topology diagram below.   Any pointers since I'm scratching my head how to get this working? Thanks in advance.
cmarva
Level 8
Level 8
if by n5k you are talking nexus 5k, check and make sure that pim is enabled. do a sho run | incl feature to verify. i think that's the reason why you can't enable pim on the svi,
Ah yes, ta. No, it's not an enabled feature.  Will turn that on to see if it fixes the problem - many thanks
Joseph W. Doherty
If you switches are running IGMP snooping, they need a IGMP querier.  The querier is generally provided by the router doing multicast to the connected interface.  Enabling PIM, on the interface (ip pim passive), should do the trick.  NB: on Nexus platforms, you also often need to enable features for them to process their corresponding configuration settings.
