Routing 2821 to Dual Wan router
mebernstein
I dont know if any of you guys can help me out with this, but I am kind of stuck.
Equiptment:
Linksys RV082 dual wan router
Cisco 2821 integrated service router
What I am trying to do is connect the RV082 to the 2 ISP's I have coming into the building(for redundancy purposes) and on one of the eight switch ports on the RV082 I want to connect to the 2821 router. From the 2821 router I want to connect a standard switch with a computer on the other end. Currently I have been working on this and think i have gotten the outside interface of the 2821 to pass the test (the outside interface is interface 0/1. The inside interface is interface 0/0). The RV082 is currenly configured as a gateway and connected to both Comcast and Bellsouth/ATT. I have posted the 2821's router configuration below for review. The ip's are as follows:
Linksys RV082 192.168.0.1
Cisco 2821 (interface 0/0) 192.168.3.1
Cisco 2821 (interface 0/1) 192.168.0.100
___________________________________________________________________________________________________________
Router configuraton file:
Building configuration...
Current configuration : 1996 bytes
version 12.4
hostname Cisco_Router
boot-start-marker
boot-end-marker
no logging buffered
enable secret 5 $1$bE/H$hMJte.pXZwXheicY6OCck.
enable password ***********
no aaa new-model
dot11 syslog
no ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 192.168.3.1 192.168.3.99
ip dhcp excluded-address 192.168.3.200 192.168.3.254
ip dhcp pool POOL
import all
network 192.168.3.0 255.255.255.0
default-router 192.168.3.1
lease infinite
voice-card 0
no dspfarm
archive
log config
hidekeys
zone security both
interface GigabitEthernet0/0
description $ETH-LAN$
ip address 192.168.3.1 255.255.255.0
ip nat inside
ip virtual-reassembly
zone-member security both
ip route-cache flow
duplex auto
speed auto
no cdp enable
no mop enabled
interface GigabitEthernet0/1
description $ETH-WAN$
ip address dhcp client-id GigabitEthernet0/1
ip nat outside
no ip route-cache
duplex auto
speed auto
no cdp enable
router rip
network 192.168.0.0
network 192.168.3.0
no auto-summary
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 GigabitEthernet0/0 permanent
ip route 192.168.0.0 255.255.255.0 192.168.0.1 permanent
ip http server
no ip http secure-server
ip nat inside source list 2 interface GigabitEthernet0/1 overload
access-list 1 remark INSIDE_IF=GigabitEthernet0/0
access-list 1 remark SDM_ACL Category=2
access-list 1 permit 192.168.3.0 0.0.0.255
access-list 2 remark SDM_ACL Category=2
access-list 2 permit 192.168.3.0 0.0.0.255
snmp-server community public RO
control-plane
line con 0
exec-timeout 0 0
line aux 0
line vty 0 4
login
scheduler allocate 20000 1000
no process cpu extended
no process cpu autoprofile hog
end
Dennis Mink
can you elaborate on what problem you are encountering with this?
Please remember to rate useful posts, by clicking on the stars below.
