Routing a subnet between 2 sites
Joshua McNeely
Hello All,
I've been trawling through the forums here and while I've found a lot of good advice, I haven't found anything that makes sense in my case. Here's what I have:
Two of our sites are being set up with a PLC network. The vendor has decided that the only good way to accomplish cross-site monitoring is to have both sites on the same subnet. I've asked them if they would please set them to separate subnets, but they refuse claiming that this shouldn't be an issue because they've done it this way at other client sites. That said, I understand it's not really the right way to do things but they won't listen to reason.
So, both sites are residing on the same subnet of 172.X.X.Z. We do have a bit of an advantage in this situation and that is the way our sites are connected. Our switches are connected directly to each other using a telco provided ethernet connection. No MPLS, no VPN, just a direct connection. The telco equipment is completely transparent to the switches.
The switchports that are connected on each end are set up like so:
interface GigabitEthernet1/0/14
  description xxxxxxx
  switchport access vlan 5  (This shouldn't matter since it's been set to trunk mode)
  switchport trunk native vlan 5
  switchport trunk allowed vlan 5,172
  switchport mode dynamic desirable
Now, if I set up a vlan interface with the 172.X.X.1 IP address on either side of the link the respective server is able to see the interface. So, the VLAN is working from the servers to the switches on both sides. However, the actual communication between the two servers (and all the PLCs on either side of the network) isn't working. It seems pretty obvious that the problem is happening somewhere on the link between the two switches but for the life of me I cannot figure out where.
Another small gotcha is that the servers are both set to use 172.X.X.1 as their default gateway. I had thought at one point that if I set up a VLAN Interface on both sides, one with .1 and one with .2 and set the servers to use those as their respective gateways that this might solve the problem. However, I'm not entirely sure if that will work if it will, whether it will require anything special or if it would be sufficient to just go
Conf t
interface vlan 172
ip address 172.X.X.1 255.255.255.0
(And similar for .2)
Thanks in advance for any help you can offer!
-Josh
31 Replies 31
I take it that it wouldn't do anything if I manually changed one of the switches to be the secondary root (just now reading up on this stuff, so pardon any brain-dead questions) would it?
You don't want to do that. The issue is not that the link isn't working because both switches see themselves are STP root but the other way round ie. both switches see themselves as STP root because the link isn't passing vlan 172.
If you changed a switch to secondary a new root needs to be found (i think, never had the situation you have now) and it can't be the other core switch because vlan 172 is not going across that link.
The order i would do it would be to get vlan 172 going across the link. Note that when it does you will get an STP convergence anyway because you have two root bridges at the moment, so there will be a slight outage. I say slight but STP has to go across all those switches and work out potentially new paths so don't do this during  key hours. Once STP has worked out which bridge is root you can then , if you are in a scheduled outage, manually set the two core switches to be root and secondary.
Like i say, i wouldn't start setting secondary roots now until the link is working for vlan 172 but i can't say for sure what would happen if you set  a secondary now.
Jon
Got it. Would this be a big issue for us to switch it over to trunk mode during on hours for vlan 5? See, as of right now vlan 172 can take however long it needs to sort things out and I won't mind. But I really don't want to have vlan 5 down for more than a few minutes at most. Not trying to get you to say yes or no, but I want to understand what sort of impact this is really going to have.
Josh
Jon Marshall
Josh
Firstly i'm not convinced this will solve the issue you are having because according to the "sh trunk" output they are already trunks. But i can't see what else is wrong in your config.
Because of all the switches i would not do this in key hours. I would schedule and outage to do this because there may be unforseen issues especially as i do not have a full picture of your network.
Can you post the config for the core switch in site B as well just so i can see if there is anything in there that may be wrong.
Jon
Sure: A note, my boss is fairly awesome about being okay with some minor disruptions (particularly on a day prior to a holiday when people don't mind leaving a bit early) we went ahead and made the change. I'm not sure how long it would take for things to work through but so far, no luck.
Using 9731 out of 524288 bytes
! Last configuration change at 04:52:06 UTC Wed Nov 27 2013 by admin
! NVRAM config last updated at 04:52:09 UTC Wed Nov 27 2013 by admin
version 12.2
no service pad
hostname xxxxxxxx
boot-start-marker
boot-end-marker
enable secret 5 xxxxxxxxxxxxxx
username nsn-msp privilege xxxxxxxxxxxxxxx
username admin privilege xxxxxxxxxxxxxxxx
aaa new-model
aaa session-id common
switch 1 provision ws-c3750x-24
switch 2 provision ws-c3750x-24
system mtu routing 1500
ip routing
ip domain-name westwardseafoods.com
stack-power stack xxxxxxxx
mode redundant
stack-power switch 1
stack-power switch 2
crypto pki trustpoint TP-self-signed-969687808
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-969687808
revocation-check none
rsakeypair TP-self-signed-969687808
crypto pki certificate chain TP-self-signed-969687808
certificate self-signed 01 nvram:IOS-Self-Sig#3838.cer
spanning-tree mode rapid-pvst
spanning-tree portfast default
spanning-tree vlan 1-1023 priority 24576
port-channel load-balance src-dst-ip
vlan internal allocation policy ascending
lldp run
interface Port-channel1
switchport access vlan 109
switchport mode access
interface Port-channel2
switchport trunk native vlan 50
switchport mode trunk
interface Port-channel3
interface Port-channel4
interface Port-channel6
switchport access vlan 108
interface FastEthernet0
no ip address
no ip route-cache cef
no ip route-cache
no ip mroute-cache
description xxxxxxxxx
channel-group 1 mode on
interface GigabitEthernet1/0/2
description xxxxxxxxxxxx
spanning-tree portfast trunk
channel-group 2 mode on
interface GigabitEthernet1/0/3
description xxxxxxxxxxxxxx
channel-group 3 mode on
interface GigabitEthernet1/0/4
channel-group 4 mode on
interface GigabitEthernet1/0/5
interface GigabitEthernet1/0/6
channel-group 6 mode active
interface GigabitEthernet1/0/7
descriptionxxxxxxxxxx
interface GigabitEthernet1/0/8
interface GigabitEthernet1/0/9
interface GigabitEthernet1/0/10
interface GigabitEthernet1/0/11
switchport access vlan 111
interface GigabitEthernet1/0/12
interface GigabitEthernet1/0/13
interface GigabitEthernet1/0/15
interface GigabitEthernet1/0/16
interface GigabitEthernet1/0/17
interface GigabitEthernet1/0/18
interface GigabitEthernet1/0/19
description xxxxxxxxxxxxxxx
interface GigabitEthernet1/0/20
interface GigabitEthernet1/0/21
interface GigabitEthernet1/0/22
switchport access vlan 125
priority-queue out
mls qos trust dscp
interface GigabitEthernet1/0/23
interface GigabitEthernet1/0/24
switchport trunk allowed vlan 111,125,172
priority-queue out
mls qos trust dscp
interface GigabitEthernet1/1/1
interface GigabitEthernet1/1/2
interface GigabitEthernet1/1/3
interface GigabitEthernet1/1/4
interface TenGigabitEthernet1/1/1
interface TenGigabitEthernet1/1/2
interface GigabitEthernet2/0/1
interface GigabitEthernet2/0/2
interface GigabitEthernet2/0/3
description ESXi2 Port 3 vmkernel
interface GigabitEthernet2/0/4
description xxxxx
interface GigabitEthernet2/0/5
description xxx
interface GigabitEthernet2/0/6
interface GigabitEthernet2/0/7
interface GigabitEthernet2/0/8
description xxxxxxx
interface GigabitEthernet2/0/9
description xxxxxxx
interface GigabitEthernet2/0/10
interface GigabitEthernet2/0/11
interface GigabitEthernet2/0/12
interface GigabitEthernet2/0/13
interface GigabitEthernet2/0/14
interface GigabitEthernet2/0/15
interface GigabitEthernet2/0/16
interface GigabitEthernet2/0/17
interface GigabitEthernet2/0/18
interface GigabitEthernet2/0/19
interface GigabitEthernet2/0/20
interface GigabitEthernet2/0/21
interface GigabitEthernet2/0/22
priority-queue out
mls qos trust dscp
interface GigabitEthernet2/0/23
interface GigabitEthernet2/0/24
priority-queue out
mls qos trust dscp
interface GigabitEthernet2/1/1
interface GigabitEthernet2/1/2
interface GigabitEthernet2/1/3
interface GigabitEthernet2/1/4
interface TenGigabitEthernet2/1/1
interface TenGigabitEthernet2/1/2
interface Vlan1
no ip address
shutdown
interface Vlan5
bandwidth 10000
ip address xxxxxxxxxxx 255.255.255.252
ip ospf authentication message-digest
ip ospf message-digest-key 1 md5 xxxxxxxxxxx
ip ospf cost 50
ip ospf 1 area 0.0.0.1
interface Vlan108
ip address xxxxxxxxxxx 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
interface Vlan109
ip address xxxxxxxxxxxx 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
interface Vlan111
ip address xxxxxxxxx 255.255.255.0
ip helper-address xxxxxxxxxx
no ip redirects
no ip unreachables
no ip proxy-arp
interface Vlan125
router ospf 1
router-id xxxxxxxxx
log-adjacency-changes
area 0.0.0.1 authentication message-digest
network xxxxxxxx.0 0.0.3.255 area 0.0.0.1
network xxxxxxxx.0 0.0.0.255 area 0.0.0.1
ip default-gateway xxxxxxxxx
ip classless
xxxxxx ip routes go here xxxxxxxxx
ip http server
ip http secure-server
ip access-list standard management
permit xxxxxxx
permit xxxxxxxx
ip sla enable reaction-alerts
snmp-server community n5nw RO management
banner login ^CC
CLOSED PRIVATE SYSTEM.  Use subject to restriction.  Authorized users only.  If you have not received previous
authorization to use this system, please disconnect immediately.  All access will be logged without further notice and can be
used as evidence in court.^C
line con 0
line vty 0 4
privilege level 15
line vty 5 15
privilege level 15
ntp clock-period 36027867
ntp server xxxxxxxxxxxx prefer
end
Can you post "sh spanning-tree vlan 172" again.
Jon
Josh
Can you also post "sh vlan brief" from both core switches ?
Jon
Site A
switch-dh-core#sh spanning-tree vlan 172
VLAN0172
  Spanning tree enabled protocol ieee
  Root ID    Priority    32940
             Address     081f.f3ca.6b80
             This bridge is the root
             Hello Time   2 sec  Max Age 20 sec  Forward Delay 15 sec
  Bridge ID  Priority    32940  (priority 32768 sys-id-ext 172)
             Aging Time  300 sec
Interface           Role Sts Cost      Prio.Nbr Type
Gi1/0/14            Desg FWD 19        128.14   P2p
Gi1/0/23            Desg FWD 4         128.23   P2p
Gi1/0/24            Desg FWD 4         128.24   P2p
Po1                 Desg FWD 3         128.488  P2p
Po2                 Desg FWD 3         128.496  P2p
Po5                 Desg FWD 3         128.520  P2p
Po6                 Desg FWD 3         128.528  P2p
Po13                Desg FWD 3         128.584  P2p
Gi2/0/19            Desg FWD 4         128.73   P2p
Gi2/0/23            Desg FWD 4         128.77   P2p
switch-dh-core#sh vlan brief
VLAN Name                             Status    Ports
1    default                          active    Gi1/0/9, Gi1/0/10, Gi1/0/11
                                                Gi1/0/12, Gi1/0/15, Gi1/0/16
                                                Gi1/0/17, Gi1/0/18, Gi1/0/19
                                                Gi1/0/20, Gi1/0/25, Gi1/0/26
                                                Gi1/0/27, Gi1/0/28, Gi2/0/9
                                                Gi2/0/10, Gi2/0/11, Gi2/0/12
                                                Gi2/0/15, Gi2/0/16, Gi2/0/17
                                                Gi2/0/18, Gi2/0/20, Gi2/0/24
                                                Gi2/0/25, Gi2/0/26, Gi2/0/27
                                                Gi2/0/28
5    VLAN0005                         active    Gi2/0/14
104  servers                          active
105  management                       active    Gi1/0/21, Gi1/0/22, Gi2/0/21
                                                Gi2/0/22
106  storage                          active    Gi1/0/3, Gi1/0/4, Gi2/0/3
                                                Gi2/0/4, Po7, Po8
125  VOICE                            active
172  PLC                              active
1002 fddi-default                     act/unsup
1003 token-ring-default               act/unsup
1004 fddinet-default                  act/unsup
1005 trnet-default                    act/unsup
Site B
switch-aly-core#sh spanning-tree vlan 172
VLAN0172
  Spanning tree enabled protocol rstp
  Root ID    Priority    24748
             Address     4055.39cc.4300
  Bridge ID  Priority    24748  (priority 24576 sys-id-ext 172)
             Aging Time  300 sec
Po4                 Desg FWD 3         128.512  P2p
Gi2/0/14            Desg FWD 19        128.68   P2p
Gi2/0/24            Desg FWD 4         128.78   P2p
switch-aly-core#sh vlan brief
1    default                          active    Gi1/0/10, Gi1/0/15, Gi1/0/16
                                                Gi1/0/17, Gi2/0/7, Gi2/0/10
                                                Gi2/0/11, Gi2/0/12, Gi2/0/13
5    VLAN0005                         active    Gi1/0/14
108  VLAN0108                         active    Po6
109  VLAN0109                         active    Gi1/0/5, Gi1/0/7, Gi1/0/8
                                                Gi1/0/9, Gi1/0/13, Gi2/0/5
                                                Gi2/0/8, Gi2/0/9, Gi2/0/18
                                                Gi2/0/19, Po1, Po3
111  VLAN0111                         active    Gi1/0/11, Gi1/0/12, Gi1/0/18
                                                Gi1/0/19, Gi1/0/20, Gi1/0/21
                                                Gi1/0/23, Gi2/0/20, Gi2/0/21
                                                Gi2/0/23
125  VOICE                            active    Gi1/0/22, Gi2/0/22
172  PLC                              active
So both ports gi1/0/14 in site A and gi2/0/14 in site B now have this config -
int
Jon
Yes. So guaranteed they aren't working in Access mode.
So that "sh vlan brief" you posted was run before or after you updated the port config ?  I ask because it is showing gi1/0/14 as being an access port in vlan 5 which it shouldn't do with the new config.
Jon
It was run after, but I forgot to do a wr to write the config changes. Here's an updated set:
Site A
                                                Gi2/0/28
104  servers                          active
                                                Gi2/0/22
                                                Gi2/0/4, Po7, Po8
125  VOICE                            active
172  PLC                              active
Site B
                                                Gi2/0/19, Po1, Po3
                                                Gi2/0/23
172  PLC                              active
It's still showing gi1/0/14 and gi2/0/14 as in vlan 5 which it shouldn't because they are no longer access ports.
One other thing i noticed was that you are running STP PVST+ on switch in site A and Rapid PVST+ on switch in site B but that should not be the issue at least i would not have thought. How many switches do you have chained off the core switch in site A ie. core switch -> switch -> etc. in a chain ?
Jon
In a single site I think we have maybe 3 or 4 chained together at most at this point. Possibly 5 but certainly no more than that.
So, if I'm hearing you right, vlans 5 and 172 should both not show any interfaces in the list if they are in trunk mode?
Josh
Yes. I think there is something more fundmental here. Are you sure the link can carry tagged traffic ie. the telco does not have any equipment in between that could be stopping this because i cannot see any reason why vlan 172 is not allowed across the link. Vlan 5 is seen on both ends by STP but vlan 172 isn't. Vlan 5 is not tagged because it is the native vlan. Can you check with the telco that you can send tagged traffic across that link ?
Jon
