Routing and switching
nmwenda01
I have configured a cisco 3850 to act as my core switch which assigns dhcp in different vlans. On the access switch I have a 2960x switch which I have configured to access one of the dhcp vlan 3. On the access and 3850 i have created a trunk port and allowed all vlans. Below is the configuration. On the 3850.
My problem is from the access switch 2960x I cannot ping the core switch but when connected to the switch in a machine I can telnet to the core switch. The core switch is receiving internet but the users on the access cannot access Internet.
3850
Inter vlan policy ascending
ip dhcp pool vlan2 network 192.168.2.0 255.255.255.0 default-router 192.168.2.254 255.255.255.0 dns-server 192.168.0.1 8.8.8.8 ! ip dhcp pool vlan3 network 192.168.3.0 255.255.255.0 default-router 192.168.1.1 255.255.255.0 dns-server 8.8.8.8
IP route 0.0.0.0 0.0.0.0 192.168.10.1
interface Vlan1
 no ip address
interface Vlan2
 ip address 192.168.2.254 255.255.255.0
 shutdown
interface Vlan3
Interface gigabitethernet 1/0/1
No switch port
IP address 192.168.10.1
Interface gigabitethernet 1/0/3
Switch port mode trunk
Switch port trunk allowed vlan all ! ip forward-protocol nd no ip http server ip http authentication local
Router eigrp 1
Network 192.168.0.0
Redistribute connected
Stub summary
Passive interface default
No passive interface gigabit ether net 1/0/1
On the access switch 2960x
Interface gigabitethernet 1/0/49
Switchport mode trunk
Switchport trunk allowed vlan all
Interface gigabitethernet 1/0/1 -1/0/48
Switchport mode access
Switchport access vlan 3
29 Replies 29
What are you tracing to on your PC?
Can you have post configs from both devices as they are currently?
configurations are the same as posted earlier Grant.
Tracing on the 192.168.10.1. Traffic reaches the 192.168.1.1 then drops
I have just labbed this up and it works absolutely fine. I did however manage to get the same symptoms as you by leaving the command "ip routing" on the access layer switch (2960).
On the 2960 can you ensure you have typed no ip routing in global config mode.
This is with regards to not being able to ping between the switches.
See the basic configs attached I used for this. I can ping the 2960 sourcing from all vlan interfaces on the 3850.
Hi Grant thanks. The access switch can ping any user machine and the core but not the gateway that is the 192.168.10.1 and has no internet.  Also from the core can ping the access switch user machines and Internet. Do I need an access list or what could I be missing ?
What is the device with the address 192.168.10.1 that is connected to gi1/0/1 with the routed port? Does it have routes back to the other 192.168.0.0 networks you have? Sounds like it doesn't and only knows about its directly connected interfaces
Hi Grant,
The device is a wireless router (192.168.10.1) which nat's internet to the public. It has no static route back to the switch. I was using a wireless TP-link as my router which doesnt understand routing back to the user . Putting a router which i can add routes back to the switch
Thank you so much for your support
Hello
if you have access too this wifi rtr then it possible to still nat your internel network from this device.
To make think more simplistic first of all do your really need all those subnets?
May just require a couple of changes to get this working?
res
paul
Kind Regards
Paul
thank you for the insight
Hello
one thing i have noticed is if i do a tracert from my pc it reaches the default gateway 192.168.1.1 then it doesnt knw where to take the traffic so i think the 3850 might be the one with an issue
3860 has these L3 interfaces with a default next hop of 192.168.10.1
interface Vlan2
interface Vlan3
interface Vlan10
ip address 192.168.0.1 255.255.255.0
interface GigabitEthernet1/0/1
ip address 192.168.10.2 255.255.255.0
ip route 0.0.0.0 0.0.0.0 192.168.10.1
2960 -
interface Vlan100
ip address 192.168.100.2 255.255.255.0
ip default-gateway 192.168.10.2
ip route 0.0.0.0 0.0.0.0 192.168.10.2
ip route 192.168.0.0 255.255.0.0 192.168.10.2
Disable ip routing on the 2960 and make sure the L2 switch has L2 vlan connectivity back to the core
For mgt purposes,  Remove that vlan 100 on the 2960 and put that switch into one of the vlans configure on the 3860
On 2960
no ip routing
no interface Vlan100
int vlan 3
ip address 192.168.1.xx
Ip default-gateway 192.168.1.1
vlan 2,3,10
exit
As for internet reachability , This all depends on how users in your 3 vlans are being delt with by you next-hop device, The reason you have internet from the 3850 is that switch has a connected interface to the nexthop device - 192.168.10.1
res
Paul
Kind Regards
Paul
The 3850 also has a vlan interface 100 now which is acting as a management VLAN and I believe he has connectivity between the 2 switches (between all interfaces on the Core and the management)
I agree that the issue is now with that next hop of 192.168.10.1 and most likely not having routes back to the other networks on the Core.
Also on the 2960 -
i would remove the following -
ip routing
Pulling this all together -
On the access switch - you want the one interface vlan 100 to be up which I think you have.
interface Vlan100
ip default-gateway 192.168.100.1
also create vlan 100
No other vlan interface required on that switch.
On 3850 -
int vlan 100
ip address 192.168.100.1 255.255.255.0
Please can you post configs as the currenty are.
Hello
give the 2960 switch an mgt IP address and default -gateway of vlan 3 and disable ip routing then you should be able to reach the L3 switch from the 2960
Make sure also that the vlans are propergated over th trunks into the vtp database of 2960 And clients can obtain dhcp addressing
Lastky your default route on the L3 is pointing to an interface on the same switch this isn't correct it should be pointing to the next-hop address for any non local traffic to route to
paul
Kind Regards
Paul
