Routing and switching
nmwenda01
I have configured a cisco 3850 to act as my core switch which assigns dhcp in different vlans. On the access switch I have a 2960x switch which I have configured to access one of the dhcp vlan 3. On the access and 3850 i have created a trunk port and allowed all vlans. Below is the configuration. On the 3850.
My problem is from the access switch 2960x I cannot ping the core switch but when connected to the switch in a machine I can telnet to the core switch. The core switch is receiving internet but the users on the access cannot access Internet.
3850
Inter vlan policy ascending
ip dhcp pool vlan2 network 192.168.2.0 255.255.255.0 default-router 192.168.2.254 255.255.255.0 dns-server 192.168.0.1 8.8.8.8 ! ip dhcp pool vlan3 network 192.168.3.0 255.255.255.0 default-router 192.168.1.1 255.255.255.0 dns-server 8.8.8.8
IP route 0.0.0.0 0.0.0.0 192.168.10.1
interface Vlan1
 no ip address
interface Vlan2
 ip address 192.168.2.254 255.255.255.0
 shutdown
interface Vlan3
Interface gigabitethernet 1/0/1
No switch port
IP address 192.168.10.1
Interface gigabitethernet 1/0/3
Switch port mode trunk
Switch port trunk allowed vlan all ! ip forward-protocol nd no ip http server ip http authentication local
Router eigrp 1
Network 192.168.0.0
Redistribute connected
Stub summary
Passive interface default
No passive interface gigabit ether net 1/0/1
On the access switch 2960x
Interface gigabitethernet 1/0/49
Switchport mode trunk
Switchport trunk allowed vlan all
Interface gigabitethernet 1/0/1 -1/0/48
Switchport mode access
Switchport access vlan 3
2 Accepted Solutions
What is the device with the address 192.168.10.1 that is connected to gi1/0/1 with the routed port? Does it have routes back to the other 192.168.0.0 networks you have? Sounds like it doesn't and only knows about its directly connected interfaces
Hello
one thing i have noticed is if i do a tracert from my pc it reaches the default gateway 192.168.1.1 then it doesnt knw where to take the traffic so i think the 3850 might be the one with an issue
3860 has these L3 interfaces with a default next hop of 192.168.10.1
interface Vlan2
interface Vlan3
interface Vlan10
ip address 192.168.0.1 255.255.255.0
interface GigabitEthernet1/0/1
ip address 192.168.10.2 255.255.255.0
ip route 0.0.0.0 0.0.0.0 192.168.10.1
2960 -
interface Vlan100
ip address 192.168.100.2 255.255.255.0
ip default-gateway 192.168.10.2
ip route 0.0.0.0 0.0.0.0 192.168.10.2
ip route 192.168.0.0 255.255.0.0 192.168.10.2
Disable ip routing on the 2960 and make sure the L2 switch has L2 vlan connectivity back to the core
For mgt purposes,  Remove that vlan 100 on the 2960 and put that switch into one of the vlans configure on the 3860
On 2960
no ip routing
no interface Vlan100
int vlan 3
ip address 192.168.1.xx
Ip default-gateway 192.168.1.1
vlan 2,3,10
exit
As for internet reachability , This all depends on how users in your 3 vlans are being delt with by you next-hop device, The reason you have internet from the 3850 is that switch has a connected interface to the nexthop device - 192.168.10.1
res
Paul
Kind Regards
Paul
29 Replies 29
GRANT3779
I would help to see all the configs or I would basing a lot on assumptions.
On the 2960x switch itself - Do you have a virtual interface/ip configured on it which is reachable from the core?
Sounds possible that you have not enabled the command ip routing on the 3850 switch but only a guess based on the available info.
Hi Grant,
NO virtual interface s set on the 2960.
Below is the whole config on 3850:
Building configuration...
Current configuration : 5605 bytes
! Last configuration change at 15:29:22 UTC Sat Jul 22 2017
version 15.2
no service pad
service password-encryption
service compress-config
hostname CORE_SWITCH
boot-start-marker
boot-end-marker
vrf definition Mgmt-vrf
address-family ipv4
exit-address-family
address-family ipv6
exit-address-family
enable password 7 02351D481F030201494D05160304071B1C0B383F
no aaa new-model
switch 1 provision ws-c3850-12s
ip routing
no ip domain-lookup
ip dhcp conflict resolution
ip dhcp excluded-address 192.168.1.10
ip dhcp excluded-address 192.168.0.1
ip dhcp excluded-address 192.168.1.251
ip dhcp excluded-address 192.168.1.252
ip dhcp excluded-address 192.168.1.253
ip dhcp excluded-address 192.168.1.250
ip dhcp excluded-address 192.168.1.245 192.168.1.250
ip dhcp pool vlan2
dns-server 41.203.208.18 41.203.208.19 8.8.8.8
ip dhcp pool vlan3
network 192.168.1.0 255.255.255.0
dns-server 41.203.208.18 8.8.8.8
ip dhcp pool vlan10
network 192.168.0.0 255.255.255.0
default-router 192.168.0.1
qos queue-softmax-multiplier 100
crypto pki trustpoint TP-self-signed-1196880361
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-1196880361
revocation-check none
rsakeypair TP-self-signed-1196880361
diagnostic bootup level minimal
spanning-tree mode pvst
hw-switch switch 1 logging onboard message level 3
redundancy
mode sso
class-map match-any non-client-nrt-class
policy-map port_child_policy
class non-client-nrt-class
bandwidth remaining ratio 10
interface GigabitEthernet0/0
vrf forwarding Mgmt-vrf
no ip address
negotiation auto
no switchport
ip nat outside
interface GigabitEthernet1/0/2
switchport mode trunk
interface GigabitEthernet1/0/3
interface GigabitEthernet1/0/4
interface GigabitEthernet1/0/5
interface GigabitEthernet1/0/6
interface GigabitEthernet1/0/7
interface GigabitEthernet1/0/8
interface GigabitEthernet1/0/9
interface GigabitEthernet1/0/10
interface GigabitEthernet1/0/11
interface GigabitEthernet1/0/12
interface GigabitEthernet1/1/1
interface GigabitEthernet1/1/2
interface GigabitEthernet1/1/3
interface GigabitEthernet1/1/4
interface TenGigabitEthernet1/1/1
interface TenGigabitEthernet1/1/2
interface TenGigabitEthernet1/1/3
interface TenGigabitEthernet1/1/4
interface Vlan1
no ip address
interface Vlan2
interface Vlan3
interface Vlan10
router eigrp 1
network 192.168.0.0
redistribute connected
passive-interface default
no passive-interface GigabitEthernet1/0/1
eigrp stub connected summary
no ip http server
ip http secure-server
ip access-list extended VLAN3
permit udp any any eq 5060
permit udp any host 192.168.0.10 eq 5060
line con 0
password 7 14341D051F0B262E042D30392D1514031311594B4C
logging synchronous
login
stopbits 1
line aux 0
stopbits 1
line vty 0 4
password 7 1331121E0509100A2E27243C33310617060C1342
login
line vty 5 15
password 7 03305E07080A356C4B0A150A11011E1C14253930
login
wsma agent exec
profile httplistener
profile httpslistener
wsma agent config
wsma agent filesys
wsma agent notify
wsma profile listener httplistener
transport http
wsma profile listener httpslistener
transport https
ap group default-group
end
Below is for the access switch:
version 15.2
no service pad
hostname ACCESS_SWITCH1
boot-start-marker
boot-end-marker
enable password 7 03374218120A2C6C4B0A150A11011E1C14253930
no aaa new-model
switch 1 provision ws-c2960x-48lps-l
ip routing
no ip domain-lookup
crypto pki trustpoint TP-self-signed-3520341632
subject-name cn=IOS-Self-Signed-Certificate-3520341632
rsakeypair TP-self-signed-3520341632
vlan internal allocation policy ascending
interface FastEthernet0
no ip address
no ip route-cache
interface GigabitEthernet1/0/1 -1/0/48
switchport access vlan 3
switchport mode access
interface GigabitEthernet1/0/49
description CONNECTION TO CORE SWITCH
interface GigabitEthernet1/0/50
interface GigabitEthernet1/0/51
interface GigabitEthernet1/0/52
interface Vlan1
no ip address
shutdown
interface Vlan100
ip http server
line con 0
password 7 0625002F5F41051C251211070302393E34383C2736
logging synchronous
login
line vty 0 4
password 7 1423170702013E0B212B3F3A24001206130E444D
login
line vty 5 15
password 7 073B2440400C0D251211070302393E34383C2736
login
end
On the 2960 -  you have vlan 100 interface in the 192.169.100.x network, which is what will be used as source when trying to reach anything physically from the switch itself. E.G if you were telnet/ssh on.
You have the ip default-gateway command pointing to 192.168.10.1. How does the switch know how to get there? If the 3850 is to be the gateway for management based traffic for the 2960 then it will need either an address on the 192.168.10.x network or you need to create another svi on the 3850 for vlan 100 and the point the ip default-gateway on the 2960 to this.
I also see some layer 3 config on the 2960 which is not required if it is being used for acces layer.
With regards to NAT, I don't think the 3850 can support NAT, although the commands are available.
weird thing is from my pc connected to the machine i can ping the core switch and telnet to it. I cannot however get internet. but from the core switch i can get to any internet service. also from the access switch i cannot ping any machine connected directly to the ports but from the core switch i can ping anyone
Your PCs have a gateway which is one if the SVIs on the core switch so they can reach it and your esse tia directly connected network in the eyes of the core switch. This is why you telnet/ping it from a PC.
From the 2960 itself, you won't be able to ping anything with the current setup. The default gateway for the 2960 needs to point to either a newly created SVI on the same address space, e.g on the 3850
int vlan 100
ip adress 192.168.100.1 255.255.255.0
on 2960
ip default-gateway 192.168.100.1
Regarding Internet - what device is doing all your NATing? What hangs off gi1/0/1?
If the 3850 is not doing the actual NAT then try adding the following commands under your vlan interfaces
ip nat inside
Hi Grant,
I have changed to all this. when i try to ping from the 2960 it says Unrecognized host or address, or protocol not running. what could i be missing.
Also from core switch with the new slv 100 i am unable to reach 192.168.10.1 from the pc
What is output of
show ip int brief
on the 2960?
The interfaces are up and protocol is up
You may need to create vlan 100 on the 2960 if it is not already there.
Show vlan
is 100 there?
yes vlan 100 is there and active. though no ports assigned to it
If it is allowed over the trunk then it should be OK. Don't need ports assigned to it as such.
show int trunk
ACCESS_SWITCH1#sh int trunk
Port Mode Encapsulation Status Native vlan
Gi1/0/49 on 802.1q trunking 1
Port Vlans allowed on trunk
Gi1/0/49 1-4094
Port Vlans allowed and active in management domain
Gi1/0/49 1-3,10,100
Port Vlans in spanning tree forwarding state and not pruned
Gi1/0/49 1-3,10,100
