Routing based on intefaces
Hi Guys,
I am wondering if we can create routes based on the interface through which the traffic is received. Please refer to the below diagram of the network.
So, what I want to achieve is, that when any traffic is received by the switch on the interface G0/1 with the destination of the Web Server, the switch should directly send it to the Web Server via interface G0/2.
But, if the traffic is received on G0/3 with the same destination of "Web Server", it should forward to the DPI server. Is that possible?Network.png
two solution
1-G0/3 and DPI G0/4 in one VRF not in global
2- using  PBR in g0/3 to direct the traffic to G0/4
two solution
Hi, Thanks for replying. Just want to know with PBR can we define routes based on the interface? Can you please elaborate on this a little bit?
Hi there,
Policy Based Routing comprises of an ACL to match traffic flows and a route-map which in your example would specify the egress interface Gi0/4. The ip policy is then applied on the ingress interface (gi0/3).
ip access-list extended 101
  permit 192.168.0.0 0.0.0.255 any
route-map DPI
  match ip address 101
  set interface gi0/4
int gi0/3
  ip policy route-map DPI
cheers,
Seb.
