Routing between 2 vlans on same device
Tracey Foster
Feeling a bit out of sorts this morning.....
I have a 3560E with 2 vlans that I want to route between.  one device with 2 vlans and route between.
Interfaces are configured as such:
int g0/11
switchport mode access
switchport access vlan 10
int g0/12
switchport access vlan 11
int vlan 10
ip address 10.10.10.1
int vlan 11
ip address 10.10.11.1
Laptops on each port with 10.10.10.2 and 10.10.11.2 configured on them.  I can ping from 10.10.10.2 to 10.10.11.1, but not to 10.10.11.2.
What do I have to configure to be able to get the 2 laptops to talk to each other?
Thank you in advance.....
Vivek Ganapathi
Level 4
Level 4
Little typos in your questions. If i consider based on your subject line, i feel you have two VLANs on the same device. For interVLAN routing to happen you need to enable it via ip routing command, which i assume you have done it as you are able to ping from 10.10.10.2 to 10.10.11.1. Another IP which you are not able to ping is 10.10.11.2?
What i feel is, this has to do something with that PC (surely running windows ). Disable the windows firewall service & give it a try.
THanks
Vivek
9 Replies 9
Try using a routing protocol:
router eigrp 100
Network 10.10.10.0
network 10.10.11.0
no auto-summary
Vivek Ganapathi
Level 4
Level 4
THanks
Vivek
I know it is not the laptops as I have been using them in the same lab and able to ping between them, just on a different segments and situations.....
I do have the IP route command in the config, just forgot to put it in there....
I will try using a routing protocol, but wish I didn't have to, as I need to keep this as simple as possible....
Hello Tracey,
Could you please explain me your setup with a topology possibly?
Vivek
Sure.
I have one 3560E.  Port g0/11 has a laptop configured with 10.10.10.2 IP, def gateway 10.10.10.1.  Port g0/12 has a laptop configured with 10.10.11.2 IP, def gateway 10.10.11.1.  I want the 2 laptops to talk to each other on the different segments.
Rest of the configuration is above....
Thanks Vivek!
I know I had put in the IP routing command!  However, I went back and checked again and it was not in there!  I put it in and am able to ping between the laptops!  Thanks for all the inputs!
I have the same issue. I tried to IP ROUTING but I could not see. See my config below.
Any suggestion.
no spanning-tree
vlan database
vlan 2
exit
voice vlan oui-table add 0001e3 Siemens_AG_phone________
voice vlan oui-table add 00036b Cisco_phone_____________
voice vlan oui-table add 00096e Avaya___________________
voice vlan oui-table add 000fe2 H3C_Aolynk______________
voice vlan oui-table add 0060b9 Philips_and_NEC_AG_phone
voice vlan oui-table add 00d01e Pingtel_phone___________
voice vlan oui-table add 00e075 Polycom/Veritel_phone___
voice vlan oui-table add 00e0bb 3Com_phone______________
interface vlan 2
ip address 10.10.9.1 255.255.255.0
exit
interface vlan 1
ip address 10.10.13.11 255.255.255.0
exit
ip route 0.0.0.0 0.0.0.0 10.10.13.1
interface  gi11
ip dhcp relay enable
exit
interface vlan 1
no ip address dhcp
exit
hostname switchd2fac1
interface gigabitethernet11
switchport access vlan 2
exit
Which device is 10.10.13.1?
It is the gateway.
