LAYER 2 PROTOCOL TUNNELING CONFIGURATION NOT WORKING ON 7600 SERIES ROUTER
vipin.vikraman
Hi all,
   i am having problem in configuring L2PT (layer 2 protocol tunneling) in my 7600 series routers.
  when i am trying to configure it i am getting this issue
76a(config t)int gi2/1
76a(config-if)#service instance 1 ethe
76a(config-if)#service instance 1 ethernet
76a(config-if-srv)#encapsulation ?
% Unrecognized command
76a(config-if-srv)#encapsulation dot1q vlan 20
% Invalid input detected at '^' marker.
is there any IOS requirement for 7600 series router to support layer 2 port channeling configuration
plz have a look at my following router information
76a#sh version
Cisco IOS Software, c7600s72033_rp Software (c7600s72033_rp-ADVENTERPRISEK9-M),
Version 15.1(3)S0a, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2011 by Cisco Systems, Inc.
Compiled Wed 10-Aug-11 21:09 by prod_rel_team
ROM: System Bootstrap, Version 12.2(17r)S2, RELEASE SOFTWARE (fc1)
BOOTLDR: Cisco IOS Software, c7600s72033_rp Software (c7600s72033_rp-ADVENTERPRI
SEK9-M), Version 15.1(3)S0a, RELEASE SOFTWARE (fc1)
76a uptime is 1 day, 29 minutes
Uptime for this control processor is 1 day, 29 minutes
System returned to ROM by  power cycle at 17:11:32 IST Wed Feb 22 2012 (SP by po
wer on)
System restarted at 17:21:01 IST Wed Feb 22 2012
System image file is "disk0:c7600s72033-adventerprisek9-mz.151-3.S0a"
Last reload type: Normal Reload
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco CISCO7604 (R7000) processor (revision 2.0) with 983008K/65536K bytes of me
mory.
Processor board ID FOX101401F7
SR71000 CPU at 600MHz, Implementation 1284, Rev 1.2, 512KB L2 Cache
Last reset from power-on
1  controller (20 GigabitEthernet).
1 Virtual Ethernet interface
70 Gigabit Ethernet interfaces
1917K bytes of non-volatile configuration memory.
8192K bytes of packet buffer memory.
65536K bytes of Flash internal SIMM (Sector size 512K).
76a#sh module
Mod Ports Card Type                              Model              Serial No.
  1    2  Supervisor Engine 720 (Active)         WS-SUP720-3BXL     SAL09264AQ
  2   48  CEF720 48 port 10/100/1000mb Ethernet  WS-X6748-GE-TX     SAL1431PK3
  3   20  ESM20G                                 7600-ES20-BASE     JAB103501E
Mod MAC addresses                       Hw   Fw            Sw           Status
  1  0013.7f0d.5554 to 0013.7f0d.5557  4.3   8.1(3         15.1(3)S0    Ok
  2  d0d0.fd64.c670 to d0d0.fd64.c69f  3.4   12.2(18r)S    15.1(3)S0    Ok
  3  00e0.aabb.cc00 to 00e0.aabb.cc00  0.64  12.2(33r)SRB  15.1(3)S0    Ok
Mod  Sub-Module                  Model              Serial       Hw     Status
  1  Policy Feature Card 3       WS-F6K-PFC3BXL     SAL09264ACZ  1.6    Ok
  1  MSFC3 Daughterboard         WS-SUP720          SAL092432MY  2.3    Ok
  2  Centralized Forwarding Card WS-F6700-CFC       SAL1431PH7S  4.1    Ok
  3  ESM20G Distributed Forwardi 7600-ES20-D3CXL    JAB103501B8  0.16   Ok
3/0 10XGE Port                  ESM-20X1GE-LINK    JAB1023004A  0.17   Ok
3/1 10XGE Port                  ESM-20X1GE-LINK    JAB1023004A  0.17   Ok
Mod  Online Diag Status
  1  Pass
  2  Pass
  3  Pass
3/0 Pass
3/1 Pass
76a#
mtsb
Hi Vipin,
I doubt if EVC is supported in 6748. Can you try in module 3 which is ES20?
Madhu
