routing between a layer 2 and a layer 3 switch
osamafaheem1974
I am trying to ping from a pc LAN 1 to a Webserver having IP address 8.8.8.8. The PC LAN 1 is a VLAN 20 having IP address 10.1.20.10 subnet mask 255.255.255.0 and I have designed a switch virtual interface (svi) for it having IP address 10.1.20.254 subnet mask 255.255.255.0. LAN 1 is connected to a layer 3 Multilayer switch and the Multilayer switch is connected to layer 2 switch and from layer 2 switch it is connected to a router having internal interface IP 10.1.11.10 subnet mask 255.255.255.0
Now whenever I am trying to ping 10.1.11.10 getting message Reply from 10.1.20.254: Destination host unreachable.
Please advice what to do I have also attached the image file although I tried to make it clear so please zoom it and please helposaassignment.jpg
post the Packet Tracer file (save the project as .pkt, then rename it to .jpg, otherwise you cannot upload it)...
Hello George
I was able to rename it to jpg but when I tried to upload it, gave me error Uploading test26.jpg resulted in the following error: Error Code: Invalid File Type, although Windows is showing it as Type of file jpg file
Is there any way to send you the file
