Routing Between TMG and VLANs ?
RaymondTPreston
I have a cisco 877w and ive setup two ssids on it each with different vlans (I intend to use the zone based firewall to lock down the guest zone later) the wireless connection is working and i can ping the entire network (because of the 10.0.0.10 interface) but none of the other computers on the network can ping the wireless ssid.
Looking in the tmg firewall logs the first ping gives
Status: The operation completed successfully.
Rule: SolarWinds Polling
Source: Internal (10.0.0.1:8)
Destination: Internal WiFi (10.0.1.1)
Protocol: PING
and then
Status: A packet was dropped because its destination IP address is unreachable.
Rule: None - see Result Code
Source: Internal (10.0.0.1:2048)
Protocol: PING
i have setup routing in tmg between the two networks (as the tmg server is the default gateway for all clients and other server including the one i pinged from).
It seems as if the first hop to 10.0.0.10 is working but after that destination IP address is unreachable. I have two free vlans & interfaces if anyone knows a simpler way to let the 10.0.1.x clients access the internal network access each other while keeping them on seperate vlans.
Show ip route gives
Gateway of last resort is 0.0.0.0 to network 0.0.0.0
S*    0.0.0.0/0 is directly connected, Dialer0
      10.0.0.0/8 is variably subnetted, 8 subnets, 2 masks
C        10.0.0.0/24 is directly connected, Vlan11
L        10.0.0.10/32 is directly connected, Vlan11
C        10.0.1.0/24 is directly connected, Dot11Radio0.1
L        10.0.1.1/32 is directly connected, Dot11Radio0.1
C        10.0.2.0/24 is directly connected, Dot11Radio0.2
L        10.0.2.1/32 is directly connected, Dot11Radio0.2
C        10.0.3.0/24 is directly connected, Vlan10
L        10.0.3.1/32 is directly connected, Vlan10
      86.0.0.0/32 is subnetted, 1 subnets
C        86.*.*.* is directly connected, Dialer0
      159.*.0.0/32 is subnetted, 1 subnets
C        159.*.*.* is directly connected, Dialer0
Ive made a quick diagram of my network its a single server with 2 NIC's one for the internal lan and another for the external network (direct connection to the router)
[img]http://upit.cc/i/927b5b84.png[/img]
My routers config is
version 15.0
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug uptime
service timestamps log datetime msec localtime show-timezone
service password-encryption
service sequence-numbers
hostname Cisco877W
boot-start-marker
boot-end-marker
security authentication failure rate 3 log
security passwords min-length 6
logging buffered 51200
logging console critical
enable secret
aaa new-model
aaa group server radius rad_eap
server 10.0.0.3 auth-port 1645 acct-port 1646
aaa group server radius sdm-vpn-server-group-1
aaa group server radius rad_mac
aaa group server radius rad_acct
aaa group server radius rad_admin
aaa group server radius rad_pmip
aaa group server radius dummy
aaa authentication login default group radius local
aaa authentication login local_authen local
aaa authentication login eap_methods group rad_eap
aaa authentication login mac_methods local
aaa authorization exec local_author local
aaa accounting network acct_methods
action-type start-stop
group rad_acct
aaa session-id common
dot11 syslog
dot11 ssid Guest Wifi
vlan 22
authentication open eap eap_methods
authentication network-eap eap_methods
authentication key-management wpa
accounting acct_methods
mbssid guest-mode
dot11 ssid MyDomain.com
vlan 21
mbssid guest-mode
no ip source-route
ip dhcp smart-relay
ip dhcp relay information trust-all
ip cef
no ip bootp server
ip domain name MyDomain.com
ip name-server 8.8.8.8
ip name-server 8.8.4.4
ip dhcp-server 10.0.0.1
no ipv6 cef
username LocalAdmin privilege 15 secret
ip tcp synwait-time 10
ip ssh time-out 60
ip ssh authentication-retries 2
ip ssh version 2
bridge irb
interface Null0
no ip unreachables
interface ATM0
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
ip flow egress
no atm ilmi-keepalive
interface ATM0.1 point-to-point
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
ip flow egress
snmp trap link-status
pvc 8/35
  pppoe-client dial-pool-number 1
interface FastEthernet0
description TMG Firewall Port
switchport access vlan 10
spanning-tree portfast
interface FastEthernet1
description Internal Network Port
switchport access vlan 11
interface FastEthernet2
shutdown
interface FastEthernet3
shutdown
interface Dot11Radio0
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
ip flow egress
beacon period 50
beacon dtim-period 50
encryption vlan 21 mode ciphers aes-ccm
encryption vlan 22 mode ciphers aes-ccm
ssid Guest Wifi
ssid MyDomain.com
mbssid
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0 54.0
packet retries 100
fragment-threshold 2307
station-role root access-point
rts threshold 2306
rts retries 100
world-mode dot11d country IE indoor
interface Dot11Radio0.1
description Internal Network Radio
encapsulation dot1Q 21
ip address 10.0.1.1 255.255.255.0
ip helper-address 10.0.0.1
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
ip flow egress
ip nat inside
ip virtual-reassembly
interface Dot11Radio0.2
description Guest WiFi Radio
encapsulation dot1Q 22
ip address 10.0.2.1 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
ip flow egress
ip nat inside
interface Vlan1
no ip address
shutdown
interface Vlan10
description VLAN For TMG Network
ip address 10.0.3.1 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
ip flow egress
ip nat inside
ip tcp adjust-mss 1452
interface Vlan11
description VLAN For Internal Network
ip address 10.0.0.10 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
ip flow egress
ip nat inside
interface Vlan21
description VLAN For Internal Wireless
ip dhcp relay information trusted
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
ip flow egress
interface Vlan22
description VLAN For Guest Wireless Network
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
ip flow egress
interface Dialer0
description ADSL Connection
ip address negotiated
no ip redirects
no ip unreachables
no ip proxy-arp
ip mtu 1452
ip flow ingress
ip flow egress
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
ppp authentication chap callin
ppp chap hostname
ppp chap password
router eigrp 1
network 10.0.0.0
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 600 life 86400 requests 10000
ip flow-export version 9
ip flow-export destination 10.0.0.1 2055
ip flow-top-talkers
top 10
sort-by bytes
ip nat inside source list 1 interface Dialer0 overload
ip route profile
ip route 0.0.0.0 0.0.0.0 Dialer0
ip access-list extended Guest-ACL
permit ip any any
logging trap debugging
logging 10.0.0.1
access-list 1 remark SDM_ACL Category=2
access-list 1 permit 10.0.0.0 0.0.0.255
access-list 1 permit 10.0.1.0 0.0.0.255
access-list 1 permit 10.0.2.0 0.0.0.255
access-list 1 permit 10.0.3.0 0.0.0.255
dialer-list 1 protocol ip permit
no cdp run
radius-server local
nas 10.0.0.3 key
radius-server host 10.0.0.3 auth-port 1645 acct-port 1646 key
control-plane
line con 0
login authentication local_authen
no modem enable
line aux 0
line vty 0 4
privilege level 15
transport input ssh
scheduler max-task-time 5000
scheduler allocate 4000 1000
scheduler interval 500
ntp server 10.0.0.2 source FastEthernet1
end
0 Replies 0
