Routing Between VRF on the same Switch C9300
a.aljiledi
I have a Cisco C9300 switch and configured with multiple VRF because I need to inspect some traffic between different VLANs by Firewall so this is why using VRF to forward traffic to the firewall,
the question is, there is any way to provide routing between different VRF on the same switch...
7 Replies 7
a.aljiledi
Example::
i need a host from vlan888 80.80.80.100 to access 70.70.70.100 without routing it to the firewall....
interface Vlan777
ip vrf forwarding VLAN777
ip address 70.70.70.1 255.255.255.0
interface Vlan888
ip vrf forwarding VLAN888
ip address 80.80.80.1 255.255.255.0
Hello @a.aljiledi ,
you cannot achieve inter VRF routing at host level with standard methods of playing with route targets.
A solution that is a workaround is to have a routed link with one side in vrf VLAN888 and one side in VRF Vlan777.
This link has to use a subnet not used anywhere
interface gi1/0/1
descrption inter VRF link
no switchport
ip address 10.88.77.1 255.255.255.252
int gi1/0/2
description inter VRF link 777 to 888
no switchport
ip address 10.88.77.2 255.255.255.2
access-list 120 remark ACL forPBR VRF VLAN888
access-list 120 permit ip host 80.80.80.100 host 70.70.70.100
access-list 121 remark ACL for PBR VRF VLAN777
access-list 121 permit ip host 70.70.70.100 host 80.808.80.100
PBR works in in rx direction
route-map PBR-VLAN888
match address 120
set ip next-hop 10.88.77.2
route-map PBR-VLAN777
match address 121
set ip next-hop 10.88.77.1
interface Vlan888
ip policy route-map PBR-VLAN888
interface Vlan777
ip policy route-map PBR-VLAN777
This configuratiion works if the two SVI intwrfaces are the default gateways for the hosts in their respective subnets.,
the two L3 ports need to be cabled with a wire.
Hope to help
Giuseppe
This is not work for me::
interface Vlan777
ip policy route-map PBR-Test1
interface Vlan888
ip policy route-map PBR-Test2
interface Vlan2020
ip address 20.20.20.1 255.255.255.0
interface Vlan3030
ip address 30.30.30.1 255.255.255.0
ip access-list extended Test1
10 permit ip host 70.70.70.20 host 80.80.80.20
ip access-list extended Test2
10 permit ip host 80.80.80.20 host 70.70.70.20
route-map PBR-Test2 permit 11
match ip address Test2
set ip next-hop 30.30.30.1
route-map PBR-Test1 permit 10
match ip address Test1
set ip next-hop 20.20.20.1
Also, I have tried to add these routes on global but still not working
ip route 70.70.70.0 255.255.255.0 Vlan777
ip route 80.80.80.0 255.255.255.0 Vlan888
i tried the same scenario on Cisco Nexus by just adding a loopback interface and create a static route on each VRF and loopback interface IP as a next hop ,,, it is works on nexus...
'Hello @a.aljiledi ,
can you provide more details on your Nexus configuration ?
is the loopback in Global routing table or in a VRF ?
Thanks in advance
Best Regards
Giuseppe
Hello @a.aljiledi ,
it cannot work because
SVI VLAN 2020 and SVI Vlan 3030 are not members of the two VRFs you would like to make to communicate so this is wrong in theory and practice.
In addition the two SVI are using different IP subnets. This is another problem you need a common subnet to have valid next-hops you cannot "jump" without a common ground ...
of course even using SVIs you stiil need to cable with a wire an access port in VLAN2020 to an access port in VLAN 3030
You are lucky they didn't work otherwise you would have bypassed your firewall for all hosts in the two subnets.
Try to implement following my suggestions on my previuos post in this thread.
I know it is a dumb solution that it is not scalable but it should work.
Hope to help
Giuseppe
Hello
@a.aljiledi wrote:
Example::
interface Vlan777
interface Vlan888
Try the following
ip route 70.70.70.0 255.255.255.0 Vlan777 < for global rib entry
ip route 80.80.80. 255.255.255.0 Vlan888  < for global rib entry
ip route vrf 777 80.80.80.100  255.255.255.255 80.80.80.100  global < for global vrf entry
ip route vrf 888 70.70.70.100  255.255.255.255 70.70.70.100  global < for global vrf entry
Kind Regards
Paul
