Routing configuration problem
muraripadhan
Level 3
Level 3
Dears
In this topology
I have done
Here vlan 1 ip 172.141.0.1/16
            PC 172.141.0.3/16
            PC 172.141.0.4/16
         Vlan 2 IP 192.168.1.1/24
     Router IP is 192.168.1.4/24
     PC IP is 192.168.1.2/24
Switch interface f0/1 and f0/2 in access vlan 2
and
all interface are in default vlan 1
Switch configuration
Switch#show running-config
Building configuration...
Current configuration : 1422 bytes
version 12.2
no service timestamps log datetime msec
no service timestamps debug datetime msec
hostname Switch
ip routing
spanning-tree mode pvst
interface FastEthernet0/1
switchport access vlan 2
switchport mode access
interface FastEthernet0/2
interface FastEthernet0/3
interface FastEthernet0/4
interface FastEthernet0/5
interface FastEthernet0/6
interface FastEthernet0/7
interface FastEthernet0/8
interface FastEthernet0/9
interface FastEthernet0/10
interface FastEthernet0/11
interface FastEthernet0/12
interface FastEthernet0/13
interface FastEthernet0/14
interface FastEthernet0/15
interface FastEthernet0/16
interface FastEthernet0/17
interface FastEthernet0/18
interface FastEthernet0/19
interface FastEthernet0/20
interface FastEthernet0/21
interface FastEthernet0/22
interface FastEthernet0/23
interface FastEthernet0/24
interface GigabitEthernet0/1
interface GigabitEthernet0/2
interface Vlan1
ip address 172.141.0.1 255.255.0.0
interface Vlan2
ip default-gateway 192.168.1.1
ip classless
ip route 0.0.0.0 0.0.0.0 192.168.1.4
ip flow-export version 9
line con 0
line aux 0
line vty 0 4
login
end
Switch#
Here 172.141.0.3 pc is communicatre with 192.168.1.3
192.168.1.3 pc is communicate with router(192.168.1.4)
But
172.141.0.3 pc is not communicate with 192.168.1.4
please send me the config file
Just it is a simple file
your routing between your switch and router , do you have a route back to the switch for the 172 network ?
6 Replies 6
Mark Malone
You have a default gateway and a default route pointing to 2 different next hops on same device  ,which one is it supposed to be remove 1 of them ? use the default route instead of default gateway as the device is doing intervlan routing and ip routing is enabled
Thanks sir i will configure then i will let u know
no sir please give me the command
Sir i removed
but 172.141.0.0/16 network is not pinging with 192.168.1.4
sir when i using pc in that port meand port no f0/1 at that time i am able to ping but when i am using router in that port i am not able to ping sir /
sir please solve the problem
