Routing Failover Issues
divine007
Hi All
I am an ISP provider with 2 internet links from my uplink provider, using BGP and Multihoming to do load balancing and failover
Now i have a client with VPN connection also high crticial data transaction, so needs to be always up
Now i have installed an iDirect Vsat for another backup link from another uplink provider using Vsat
But now the Vsat iDirect do not handle BGP session, so am stuck in active
And right now am block because no funds to change vsat for that compatible with BGP
What must i do in other that there is a failover with the second Provider when the First is completely down
Putting in mind that my client is using VPN connection to communicate with its distantly
rais
Level 7
Level 7
Do you have your own IP space?
Who is VPNing from and where to?
Thanks.
yes we do own public ip address address segment
we are in cameroon and the other india
So we want to do it in such a way that only their segment failover to the Vsat since it not much capacity. But until it failover it needs to keep going through our main provider
Any suggestion??
