routing family
alsayed
hello
what is the routing family which the router has to build map for the routing domain?
thank
6 Replies 6
Giuseppe Larosa
Hello Ali,
I'm not sure to have understood
BGP can use address-families
the conventional address family used to exchange IPv4 NLRI is
address-family ipv4 unicast
other address families exist to address different needs:
address-family ipv4 multicast
address-family vpnv4
signalling plane for L3 VPN
address family ipv4 vrf vrf-name
used for L3 VPN
address-family ipv6
and so on.
the address-family are the arguments the two speakers can talk about
Hope to help
Giuseppe
Harold Ritter
Ali,
Are you referring to Link State routing protocols, in which all routers have to build a root tree to all other routers in the network with themselves as the root.
In this case, you could include ospf and isis for IP and nlsp for ipx.
hello
i mean how the router has to build map for the routing domain
2)when we use LAS typ4 in OSPF?
THANKS
Ali,
Each router runs the Shortest Path First (SPF) algorithm and build a root tree with itself as the root. The result of this calculation is a best path to each subnet in the network.
2) OSPF LSA type 4 is used to provide connectivity to a given ASBR. All areas in the autonomous system will have this lsa type 4, except for the area where the ASBR resides. This area doesn't need the LSA type 4 to calculate connectivity to the ASBR as it will use the LSA type 1 and 2 to do so.
HELLO AGAIN
WHAT'S THE MEANING OF ADDRESS-FAMILY?why they called it address-family?
THANKS
Ali,
Address-family is just what the name indicates, different family of addresses. For exemple, IPv4, IPv6, IPX, AppleTalk, etc.
Please refer to the following document for a list of registered address-family numbers:
http://www.iana.org/assignments/address-family-numbers/address-family-numbers.xhtml
