Routing for VLANs
htshurup21
Hello everybody.
In my HomeLab I have 2960G-48 switch  with VLANs 10,32,64,90 for vMotion,100 - for esxi hosts.
Switch connection comes from 1921 router from gig0/0 to gig0/44 on switch.
Default network is 192.168.0.0 255.255.255.0
On router gig0/0 has IP 192.168.0.1 255.255.255.0
IPs on VLANs:
10 -192.168.10.0
32- 192.168.32.0
64- 192.168.64.0
90- 192.168.90.0
100- 10.100.100.0
IPs have been assigned to sub interfaces on router with numbers of the VLANs (ie   gig0/0.10 , gig0/0.32....etc)
When Im setting up on router    ip route 192.168.10.0 255.255.255.0 192.168.0.0   Im still not able to get to the hosts on that subnet.
Trunk has been setup on switch on port gig0/44 as it connects with gig0/0 on router.
Native for trunk is 80 and is being setup on port gig 0/44 on switch.
interface GigabitEthernet0/1
switchport access vlan 100
switchport mode access
Same settings are on other interfaces on switch.
From switch I can ping gig0.0.10 or  sub interface gig 0/0.10 on router, but cannot ping any other sub interface.
Could you please tell me what am I doing wrong?
Sorry for my broken english.
Vitalii
21 Replies 21
My topology looks like you've mentioned
Router -- Sub-int----trunk--Switch
Did read your previous comments and applied those settings to a router:
no  ip address 192.168.0.1 255.255.255.0
no  ip nat inside
also did
no ip route 192.168.10.0 255.255.255.0 192.168.0.0
no ip route 192.168.32.0 255.255.255.0 192.168.0.0
no ip route 192.168.64.0 255.255.255.0 192.168.0.0
Why do I have to do    no ip address 192.168.0.1 255.255.255.0     ?? Its my main internal LAN for home
Sorry if Im not understanding, just getting into it.....
version 15.1
service password-encryption
hostname MainGate
boot-start-marker
boot-end-marker
enable secret 5 !!!!!!!!!!!!!!!!!!!!!
aaa new-model
aaa authentication login default local
aaa session-id common
memory-size iomem 10
no ipv6 cef
ip source-route
ip cef
ip dhcp excluded-address 192.168.0.1 192.168.0.99
ip dhcp excluded-address 192.168.0.200 192.168.0.254
ip dhcp pool Lan
 network 192.168.0.0 255.255.255.0
 default-router 192.168.0.1
 dns-server 8.8.8.8
ip name-server x.x.x.13
ip name-server x.x.x.242
ip name-server 8.8.8.8
ip inspect name DNS dns
ip inspect name ICMP icmp
ip inspect name NTP ntp
ip inspect name Router-trafic router
ip inspect name Router-trafic tcp router-traffic
crypto pki trustpoint TP-self-signed-1453036957
 enrollment selfsigned
 subject-name cn=IOS-Self-Signed-Certificate-1453036957
 revocation-check none
 rsakeypair TP-self-signed-1453036957
crypto pki certificate chain TP-self-signed-1453036957
 certificate self-signed 01
  3082022B 30820194 A0030201 02020101 300D0609 2A864886 F70D0101 05050030
  31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
  69666963 6174652D 31343533 30333639 3537301E 170D3137 30333037 30333338
  31345A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
  4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D31 34353330
  33363935 3730819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
  8100CE54 F75192CF 93A8122E DA303E05 F01DA588 0FAEB9BE 67A5DCA5 0A163734
  D8F4AF72 362DD848 3269B677 B2EDC3DB 90AD9AB8 0DD26BC5 7EC907C5 D9CD20AC
  E89C2FD9 A05D873C 2D550AD2 718E431B 2DD41789 7EC76EEF B7C59273 6CD54700
  A24A41B2 C9703699 54B79E52 112FD7A5 F38E0E63 21EF15CE 102A81BC 6E26152D
  3AE70203 010001A3 53305130 0F060355 1D130101 FF040530 030101FF 301F0603
  551D2304 18301680 141FF321 5FF756EA 76A8CAF5 7D73C2CE 86182DB1 6B301D06
  03551D0E 04160414 1FF3215F F756EA76 A8CAF57D 73C2CE86 182DB16B 300D0609
  2A864886 F70D0101 05050003 8181007B EFDD9503 9A887AAE 537F98E7 FAA618EF
  91E3C922 2F5F4778 6D6505EF 117859DC 3DB46E32 F31EFD0E 2775BA99 2FBB03F5
  E3AC7FB7 D8C0EA6E E362F2AA D5F5541A 066F6CD7 07357748 C6E4AD2C 056C23E8
  9540F3B9 34388428 9E1E6438 E21E4A6C B643DDD4 3249AC28 558C642E D4460986
  75E364C8 53A92070 861AF125 FF84BC
  quit
license udi pid CISCO1921/K9 sn FTX154282Z1
license boot module c1900 technology-package securityk9
license boot module c1900 technology-package datak9
archive
 log config
  logging enable
  hidekeys
username root privilege 15 secret 5  !!!!!!!!!!!!!!
username vpnuser1 secret 5 !!!!!!!!!!!!!!!!
redundancy
ip tftp source-interface GigabitEthernet0/0
ip ssh authentication-retries 2
ip ssh version 2
crypto isakmp policy 10
 encr 3des
 hash md5
 authentication pre-share
 group 2
crypto isakmp client configuration group homevpn
 key SECRET
 dns 192.168.0.2
 pool VPN-POOL
 acl 110
crypto isakmp profile homevpn
   match identity group homevpn
   client authentication list USER-AUTH
   isakmp authorization list GROUP-AUTH
   client configuration address respond
crypto ipsec transform-set homevpn esp-3des esp-md5-hmac
crypto map homevpn 10 ipsec-isakmp
 ! Incomplete
 set peer x.x.x.218
 set security-association lifetime seconds 86400
 set transform-set homevpn
 match address 110
interface Embedded-Service-Engine0/0
 no ip address
 shutdown
 description LabLan
 ip accounting output-packets
 ip nat inside
 ip virtual-reassembly in
 duplex auto
 speed auto
interface GigabitEthernet0/0.10
 encapsulation dot1Q 10
 ip address 192.168.10.1 255.255.255.0
interface GigabitEthernet0/0.32
 encapsulation dot1Q 32
 ip address 172.32.32.1 255.255.255.0
interface GigabitEthernet0/0.50
 encapsulation dot1Q 50
 ip address 10.50.50.1 255.255.255.0
interface GigabitEthernet0/0.64
 encapsulation dot1Q 64
 ip address 192.168.64.1 255.255.255.0
interface GigabitEthernet0/0.90
 encapsulation dot1Q 90
 ip address 192.168.90.1 255.255.255.0
interface GigabitEthernet0/0.100
 encapsulation dot1Q 100
 ip address 10.100.100.1 255.255.255.0
interface GigabitEthernet0/0.200
 encapsulation dot1Q 200
 ip address 192.168.200.1 255.255.255.240
interface GigabitEthernet0/0.240
 encapsulation dot1Q 240
 ip address 192.168.240.1 255.255.255.0
interface GigabitEthernet0/0.245
 encapsulation dot1Q 245
 ip address 192.168.245.1 255.255.255.0
 description Internet
 ip address x.x.x.218 255.255.255.252
 no ip redirects
 no ip proxy-arp
 ip nat outside
 ip verify unicast reverse-path
 duplex auto
 speed auto
 no cdp enable
 crypto map homevpn
interface Virtual-Template10
 ip unnumbered GigabitEthernet0/1
 peer default ip address pool VPN-POOl
 ppp encrypt mppe auto
 ppp authentication ms-chap-v2
ip local pool VPN-POOL 192.168.0.240 192.168.0.250
ip default-gateway x.x.x.217
ip forward-protocol nd
no ip http server
no ip http secure-server
ip dns server
ip nat inside source list 100 interface GigabitEthernet0/1 overload
ip nat inside source static esp 192.168.0.2 interface GigabitEthernet0/1
ip nat inside source static tcp 192.168.0.15 x.x.x.218 25 extendable
ip nat inside source static tcp 192.168.0.2 80 x.x.x.218 80 extendable
ip nat inside source static tcp 192.168.0.15 110 x.x.x.218 110 extendable
ip nat inside source static tcp 192.168.0.15 143 x.x.x.218 143 extendable
ip nat inside source static tcp 192.168.0.2 443 x.x.x.218 443 extendable
ip nat inside source static tcp 192.168.0.15 465 x.x.x.218 465 extendable
ip nat inside source static udp 192.168.0.2 500 x.x.x.218 500 extendable
ip nat inside source static tcp 192.168.0.15 585 x.x.x.218 585 extendable
ip nat inside source static tcp 192.168.0.15 993 x.x.x.218 993 extendable
ip nat inside source static tcp 192.168.0.15 995 x.x.x.218 995 extendable
ip nat inside source static udp 192.168.0.2 1701 x.x.x.218 1701 extendable
ip nat inside source static udp 192.168.0.2 4500 x.x.x.218 4500 extendable
ip route 0.0.0.0 0.0.0.0 x.x.x.217
ip access-list extended FIREWALL
 permit tcp any any eq 22
ip access-list extended VPN-POOL
 permit ip 192.168.0.0 0.0.0.255 any
access-list 1 permit 192.168.0.254
access-list 100 permit ip 192.168.0.0 0.0.0.255 any
control-plane
line con 0
line aux 0
line 2
 no activation-character
 no exec
 transport preferred none
 transport input all
 transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
 stopbits 1
line vty 0 4
 privilege level 15
 transport input ssh
scheduler allocate 20000 1000
ntp server 17.253.24.125
ntp server 17.253.24.253
ntp server 17.253.4.125
end
No configuration should be configured under the interface g0/0 if you are using subinterfaces. And you are missing the subinterface for native vlan 80
 description LabLan
no  ip nat inside
 duplex auto
 speed auto
inter g0/0.80
encapsulation dot1q 80 native
If you want to provide internet access for the internal subnets (related to the sub interfaces) you can configure the ip nat inside under each sub-interface
int g0/0.10
ip nat inside
int g0/0.32
ip nat inside
int g0/0.64
ip nat inside
and the same for the rest of the sub interfaces. For the subinterface for the vlan 80 is not required.
Remember, you dont need static route to know the internal subnets because they are directly connected to the router.
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
Dennis Mink
Vitalii
Have you set a default gateway on your switch to point to the IP address of the Gi0/0.10 on your router?
Is there any particular reason you are using native VLAN 80?
Please rate if useful
Please remember to rate useful posts, by clicking on the stars below.
No I have not set a default gateway on my switch.
Please, may I have a proper command to do this?
There is no reason in particular for using VLAN 80 for native. Should I just use VLAN 1 for it?
Vitalii
You can use a native vlan different to 1, actually a good practice is disable the vlan 1 for security purposes.
add a default gateway to point to the router, like I indicate in previous post, then see if you can ping for instance gi0/0.32 from your switch. Now dont forget you dont need an IP address in each vlan on your switch if you let the router do the intervlan routing. only one IP address to be able to telnet in is enough.
so all your hosts will need to point to your routers IP address of their respective VLANs.
