routing guest net to separate WAN
jozefvl68
I have a cisco 877 connected on the wan side to two different network providers.
On the lan side I have an untagged network on subnet 10.0.0.0 and tagged guest net on 192.168.1.0
currently both are routed out through fastethernet 0 (vlan 1)
I actually want to route the tagged net fastethernet 1 (vlan 3) so I can use different providers.
With the current setup both normal and guest net work with the dhcp pools.
However, when I change the guest dhcp pool to 192.168.2.0 network, I stop getting IP addresses.
ip dhcp pool guest
network 192.168.2.0 255.255.255.0
default-router 192.168.2.1
end
what am I missing?
blau grana
Level 7
Level 7
Hello jozef,
you ment vlan2, vlan 1 is your 10/8 internal network.
You have to configure policy based routing for guest network
interface LAN_interface
ip address 192.168.1.0 255.255.255.0
ip policy route-map PBR_MAP
ip access-list extended network_guest
permit ip 192.168.1.0 0.0.0.255 any
deny   ip any any
route-map PBR_MAP permit 10
match ip address network_guest
set ip next-hop NEXT_HOP-you_want_to_use
ip dhcp pool guest
end
what am I missing?
You can not change guest pool just like that.
interface Vlan2
ip address 192.168.1.2 255.255.255.0
interface Vlan3
ip address 192.168.2.2 255.255.255.0
If guest pool is 192.168.1.0/24, users on Vlan2 will obtain IP addresses and users on Vlan3 will not. When you change guest pool to 192.168.2.0/24, users on Vlan3 obtain IP addresses and users on Vlan2 not.
LANnetwork has to match with DHCP pool for DHCP to work on that LAN segment.
Best Regards
Please rate all helpful posts and close solved questions
Best Regards Please rate all helpful posts and close solved questions
First of all, thanks for your reply.
the command int LAN_interface is not an accepted interface
could you direct me to the correct one? should I make a virtual-access2 instead?
it only accepts the following:
routercisco1(config)#int ?
  ATM                 ATM interface
  Async               Async interface
  BVI                 Bridge-Group Virtual Interface
  CDMA-Ix             CDMA Ix interface
  CTunnel             CTunnel interface
  Dialer              Dialer interface
  FastEthernet        FastEthernet IEEE 802.3
  Group-Async         Async Group interface
  Lex                 Lex interface
  Loopback            Loopback interface
  Multilink           Multilink-group interface
  Null                Null interface
  Tunnel              Tunnel interface
  Vif                 PGM Multicast Host interface
  Virtual-Access      Virtual Access interface
  Virtual-Dot11Radio  Virtual dot11 interface
  Virtual-PPP         Virtual PPP interface
  Virtual-Template    Virtual Template interface
  Virtual-TokenRing   Virtual TokenRing
  Vlan                Vlan IEEE 802.1q
  range               interface range command
  vmi                 Virtual Multipoint Interface
thanks in advance
Hello Jozef,
Sorry for the confusion.
LAN_interface -> is just alias for your real LAN interface, from information you have provided is not clear which one is it.
So if your LAN interface (Layer 3 interface -> gateway) is for example Vlan 222, you will apply policy-map on this interface.
interface Vlan 222
Policy map which I created is for 192.168.1.0/24 network, so you have to apply that policy map on interface where that network is terminated.
Best Regards
