Routing http traffic
terrencepayet
Hi Guys,
Quick question.
Lets say i have two ISP's (ISP 1 and ISP 2). Can i route all http and https traffic to one ISP1 and route smtp,vpn etc to ISP 2?
Thanks & regards,
Terence
cadet alain
yes you can using PBR.
access-list 100 permit tcp any any eq 80
access-list 100 permit tcp any any eq 8080
access-list 100 permit tcp any any eq 443
access-list 110 permit tcp any any eq smtp
route-map PBR permit 10
match ip address 100
set ip next-hop x.x.x.x   where x.x.x.x is ISP1 next-hop
route-map PBR permit 20
match ip address 110
set ip next-hop y.y.y.y  where y.y.y.y is ISP2 next-hop
int fx/x
ip policy route-map PBR  where fx/x is your router LAN ip address
if you are doing NAT then you'll have to do this also
route-map ISP1
match interface
route-map ISP2
match interface
ip nat inside source route-map ISP1 interface
ip nat inside source route-map ISP2 interface
Regards.
Alain.
Hi Alain,
Thanks.
I was reading about PBR before posting the question. But i wasn't sure, but now you've cleared my mind.
I will try it and will let you know the outcome.
Thanks again.
Best Regards,
Terence
